Spicing up the sexlife!
PinkPrincess
  • Replies 111
  • Created
  • Last Reply
Top Posters In This Topic
Calling Chri5 - this is definately his area of expertise!
I did see on one particular site some sort of hanging contraption combined with what looked like some rather uncomfortable leather gear. I guess if you do end up in B&Q a garden swing could be adapted to be sort of similar. Now, let me have a look for that link ...
I have no idea what you mean Sir :rolleyes:
You are the guy that manages to find a new g/f seemingly on demand, so I'd suggest you are better qualified than most.
PP- you have already stated your bi, so I'd expect you to have pretty well much covered the standard combinations- same sex, male sex and a bit of both same time type partnering fun.
Imagination is key to what you feel will enhance your fun and only you and your intended partners will know what will be 'user friendly' for you.
Why not start off with setting out to try something you haven't tried (there's always something new and the net would be a easy source of discovery if you lack imagination) and take it from there ?
Or get each partner to write down 5 things they'd like to try on a list, you do the same. Compare lists, and anything the same "bingo".
Role playing, outside adventure, diy porno, dressing up, it's all down to the imagination.
If all you were referring to was a shop bought item, if you haven't tried a mini bullet vib then you could be in for a treat. Use it while in coitus and it will help improve your moment(s) and the resulting strong contractions should improve your partners moment(s) as well.
If all else fails why not make Collease you new toy :P
"I have no idea what you mean Sir
You are the guy that manages to find a new g/f seemingly on demand, so I'd suggest you are better qualified than most."
Touche! But I do like the way you found a good few paragraphs on the subject. +++
Let you off then Brabus :P
I have done inside, outside, karma sutra front to back and back again! Now I never dress down ;)
Have you ever tried a Pinwheel? Wondering if they are any good?
You could always post a few provocative pics on an internet forum - or send some utter filth to a total stranger via pm.
I am quite open minded about this sort of thing!
If you need to spark things up, you could try a bag of goodies from mystim.
I've not had (or would want) a play with such items, but each to their own. They are Electro sex toys, I think they work on the same principle as tens units. They are set to fire electric shocks and depending on what add on's you get they stimulate pretty well anywhere you might want.
Rumour is that they can make either sex have climaxes with any other help.
I get the odd shock via job, and I've never found that very stimulating- but each to their own.
Do report your findings.......
Guest
This topic is now closed to further replies.
