hydraulicmoments Posted April 22, 2011 Report Share Posted April 22, 2011 Hi guys im at a total loss of ideas to sort out my golf!! she starts fine first time every time but drive up the road she is very under powered give it half a mile the ASR light comes on and she starts shuddering some times its a light wheel wobble shudder or it can feel like the engine is about to drop out!! flick the ignition off and back on in motion, normal driveabillity is restored but still under powered, then the fault will return after a mile or so:confused: Iv read the fault codes: all 4 injectors exceeded limmit intermittent signal??? looked at auto data and checked : 1, injector resistances and all ok 2, replaced fuel temp sensor ok 3, replaced engine temp sensor ok 4, replaced brake pedel switch ok 5, checked injector loom in head all looks lovely all conectors tight all insulation in good condition 6, changed all 4 injector rocker tappets!!!! Now fed up and hate my golf i find it impossible to belive all 4 injectors are faulty im thinking mabe electrical or fuel pump but have lost faith and need advice someone must have had this trouble so please help! cheers jack. Link to comment Share on other sites More sharing options...
