cruiser647 Posted May 17, 2011 Report Share Posted May 17, 2011 My mate is currently looking at a few 2007 A6's. He's seen a few and most have a Bluetooth option of some sort. The questions he has are:- Are those age Bluetooth consoles compatible with modern phones? He saw one with an optin on the MMI of 'Clear Devices' and 'PIN'. Does this mean the phone searches for the car and then connects? If the Bluetooth is shi1te, can he upgrade it at all? I think these are mostly aimed at Mr Craigyb..... Thank you! Link to comment Share on other sites More sharing options...
CarMad Posted May 17, 2011 Report Share Posted May 17, 2011 No idea to most of the questions but the bluetooth and the options menu on my MMI 2010 A6 is great and works with the iPhone no problems at all for all the features that I use. Link to comment Share on other sites More sharing options...
craigyb Posted May 17, 2011 Report Share Posted May 17, 2011 Well the good thing is that the buetooth can be updated to the latest version which is 1130 or 1120 for BTA modules. This will work with most modern phones including iphone. Link to comment Share on other sites More sharing options...
cruiser647 Posted May 17, 2011 Author Report Share Posted May 17, 2011 He's got either an HTC Desire or might have upgraded to a different HTC style Android phone. I'll let him know! Thanks! Link to comment Share on other sites More sharing options...
cruiser647 Posted May 23, 2011 Author Report Share Posted May 23, 2011 A few more questions about MMI, AMI stuff on the A6 3.0 TDi (57 plate) Can AMI be retrofitted? Can Full Voice command be fitted? Can MMI be upgraded and where do the Nav updates come from? And Hidden Menu - does the car need to be running to get this up? Thanks! Link to comment Share on other sites More sharing options...
Cockney Boy Posted May 23, 2011 Report Share Posted May 23, 2011 Yes Yes And from the latest Nav DVD Craig fitted SDS and AMI to my A6 when it was the 2G version. I highly recommend it Link to comment Share on other sites More sharing options...
cruiser647 Posted May 25, 2011 Author Report Share Posted May 25, 2011 How much for an AMI upgrade? How much for an MMI upgrade? And how do you get to the 'hidden menu' to eject the Nav DVD? Link to comment Share on other sites More sharing options...
Cockney Boy Posted May 25, 2011 Report Share Posted May 25, 2011 Give either Craig at tclsatnav or Gareth at VWcruise they could give you a price How much for an AMI upgrade?How much for an MMI upgrade? And how do you get to the 'hidden menu' to eject the Nav DVD? Link to comment Share on other sites More sharing options...
craigyb Posted May 25, 2011 Report Share Posted May 25, 2011 Hidden menu is ony available if the MMI controller has been programmed to enable it. Controller 07, Adaptation channel 8 = 1 AFAIK there is no eject option in the hidden menu. You have to change the DVD lock/eject setting in the DVD nav module. Controller 37, adaptation 68 = 0 (eject button active) Link to comment Share on other sites More sharing options...
cruiser647 Posted May 26, 2011 Author Report Share Posted May 26, 2011 Hidden menu is ony available if the MMI controller has been programmed to enable it. Controller 07, Adaptation channel 8 = 1AFAIK there is no eject option in the hidden menu. You have to change the DVD lock/eject setting in the DVD nav module. Controller 37, adaptation 68 = 0 (eject button active) So that needs to be activated first with VAG-Com? Link to comment Share on other sites More sharing options...
craigyb Posted May 26, 2011 Report Share Posted May 26, 2011 Yes, it is not enabled by default. Link to comment Share on other sites More sharing options...
