Goz Posted September 15, 2011 Report Share Posted September 15, 2011 Hello, Can the pedal sender be swapped with the pedal module ? (i realise this means a different pedal block casting). What I really need to know is does the ECU see the same signal from the sender and the module? I dont need a different ECU? Just plug and play (and of course re-set the kickdown with VagCom). Thanks Goz Link to comment Share on other sites More sharing options...
