Jamez3
A8 Brake warning symbol will not clear??????
2 posts in this topic
Hi, I recently changed my front pads and a calliper which had seized and now the pad low warning symbol in the centre of the dash will not clear?
I have double checked all connections, made sure wires are cable tied back out the way, no rubbing visible etc..brakes work fine except for the warning symbol?
I expected this to clear once pads were replaced - is there anything else I should be doing??
thanks in advance.....
Possible there's a problem with the wires, or if it's a D3, your rears need looked at too.
