planetxmat Posted March 12, 2012 Report Share Posted March 12, 2012 Hi there have had a search and not come up with anything so i thought i would ask where other than under the passenger seat would i find the telemetric unit ? I have just fitted the denison gateway 500 and the bluetooth module, and when i make phone calls they cut out after 10 seconds now this is because the audi phone is overriding the dennison bluetooth but i can't find the telemetric unit, which is supposed to be under the passenger seat it's not there so where else can it be ? Thanks in advance Matt Link to comment Share on other sites More sharing options...
craigyb Posted March 12, 2012 Report Share Posted March 12, 2012 Telemetric or Telematics? I thought that was US only. The phone ECU is under the floor on the front left. So if the car is RHD then it is under the passenger floor, if it is LHD then it is under the drivers floor. Link to comment Share on other sites More sharing options...
planetxmat Posted March 12, 2012 Author Report Share Posted March 12, 2012 right so I looked under there and there was no ecu so I am guessing there is no phone prep that unfortunately doesn't solve my problem any one got any idea how to solve the problem of the bluetooth cutting out a couple of seconds into a call? Link to comment Share on other sites More sharing options...
craigyb Posted March 12, 2012 Report Share Posted March 12, 2012 Listen to what is being said, under the FLOOR, not the seat, you will have to remove the seat and lift the carpet to get to the ECU. It is inside a large plastic box under the FLOOR. Link to comment Share on other sites More sharing options...
planetxmat Posted March 12, 2012 Author Report Share Posted March 12, 2012 when i removed the seat and carpet all i found was a wiring loom and an air vent Link to comment Share on other sites More sharing options...
craigyb Posted March 13, 2012 Report Share Posted March 13, 2012 Are you sure you have factory bluetooth? It seems very strange. Also is your car actually a C6 chassis with MMI 2G and control around the bottom of the gear leaver? Or is it a C5 chassis car with the RNS-E in the dash? Link to comment Share on other sites More sharing options...
planetxmat Posted March 13, 2012 Author Report Share Posted March 13, 2012 it's a c6 it has mmi 2 i think that it doesn't have phone prep, i have a dennison gateway 500 with the dennison bluetooth module when i make or receive calls they cut out after a couple of seconds, dennison say i must have a phone prep in my car, i just can't find it Link to comment Share on other sites More sharing options...
craigyb Posted March 13, 2012 Report Share Posted March 13, 2012 The only place phone prep is installed in a C6 is under the left front seat, if it's not there you don't have it. Another easy way to tell is look at the right hand mic grill in the lighting dome. If you can see daylight through teh grill then there is no mic for blutetooth and hence no bluetooth or phone prep. Link to comment Share on other sites More sharing options...
planetxmat Posted March 13, 2012 Author Report Share Posted March 13, 2012 ace i was sure i didn't have a phone, that's why i got the dennison and the bluetooth module why would the car keep switching off the phone call after a few seconds if there is no phone installed, is there a setting i need to adjust? Link to comment Share on other sites More sharing options...
craigyb Posted March 13, 2012 Report Share Posted March 13, 2012 Don't know, don't like the BTA1500 as a product so don't use them. Link to comment Share on other sites More sharing options...
planetxmat Posted March 13, 2012 Author Report Share Posted March 13, 2012 can you suggest any alternatives? Link to comment Share on other sites More sharing options...
