00193 Right Rear Door Handle Touch Sensor, Short to ground
Ridley Scott
Hi All. Having recently done a Auto Scan for a "02439 Right Rear Parking Brake Motor Hall Sensor" I came across the abvove fault code and sure enough if you touch the handle it fails to open. Does the handle require replacement or is there an easier fix. Also any help with the other issue greatly apriciated.
  • 2 weeks later...
