drumstick Posted April 9, 2012 Report Share Posted April 9, 2012 Hello. ive just found that the carpets in my C5 were soaking. this is only on the near side of the car (front and rear). the carpet running down from the thresholds are dry. and there are no signs of water coming in around any of the door seals. i have checked under the car for any missing grommets and drew a blank there too. i then looked under the battery cover and found a small swimming pool. is it possible that the water is getting in from there through the bulkhead and running down through the car across the floor. i have dried it out now, but am concerned about it happening again. are there drain holes in there that are blocked? any feed back would be great mat Link to comment Share on other sites More sharing options...
jsuka6 Posted April 9, 2012 Report Share Posted April 9, 2012 Had this on my (then) brand new C5 A6. Turned out to be a cracked battery cover allowing water in. I also think the pollen filters are located there and that is a common cause of the problem if they are not fitter correctly. Also check all of the drain holes in and around the battery and cover area are clear as that may be the cause of the water having to find somewhere to go Link to comment Share on other sites More sharing options...
drumstick Posted April 9, 2012 Author Report Share Posted April 9, 2012 thanks for the reply jsuka6, i think that will be my next step. battery out pollen filter out and a good clean! Link to comment Share on other sites More sharing options...
cruiser647 Posted April 10, 2012 Report Share Posted April 10, 2012 Also make sure the holes under the battery cover are cleared. Link to comment Share on other sites More sharing options...
