Tombstone08 Posted April 23, 2012 Report Share Posted April 23, 2012 I have an '06 2.7tdi A6 Avant - I discovered this week that there is significant water inside my nearside front sill, underneath the bluetooth module (which I was changing) case, the wiring loom there was under water! This water is clean, I mean totally clean and clear, looks like it just came from a tap!. This suggests rainwater ingress while parked. I would welcome any knowledge on places to start searching for the leak? Link to comment Share on other sites More sharing options...
Mort Posted April 24, 2012 Report Share Posted April 24, 2012 Air con drain pipe blocked - its a common problem. Link to comment Share on other sites More sharing options...
Tombstone08 Posted April 24, 2012 Author Report Share Posted April 24, 2012 Thanks Mort, appreciate the tip. Can you tell me where this pipe is so I can get un-blocking!? Link to comment Share on other sites More sharing options...
craigyb Posted April 24, 2012 Report Share Posted April 24, 2012 Also the rear wash wipe pipe has a joint just ahead of the BT module, make sure that has not split apart. Although it would probably smell of bad eggs if it was the rear wash wipe pipe. Link to comment Share on other sites More sharing options...
Tombstone08 Posted April 24, 2012 Author Report Share Posted April 24, 2012 Thanks for the info, I don't think its from the washer bottle as the water there is tinted blue screen wash/anti-freeze. Air con condensation sounds possible though. Link to comment Share on other sites More sharing options...
Mort Posted April 25, 2012 Report Share Posted April 25, 2012 never fixed it myself.... but this might help you : How to clean out the evaporator drain valve..... - AudiWorld Forums Link to comment Share on other sites More sharing options...
jsuka6 Posted April 25, 2012 Report Share Posted April 25, 2012 never fixed it myself.... but this might help you : How to clean out the evaporator drain valve..... - AudiWorld Forums caution, this link relates to the C5 A6 and not the C6 platform, which your car is. Not saying the cause is not the same but the process of getting to it and clearing may be different Link to comment Share on other sites More sharing options...
Tombstone08 Posted April 27, 2012 Author Report Share Posted April 27, 2012 All comments noted and advise on board. An Audi specialist also said to check the ECU housing for water & blocked drain grommets. Looks like I'm in for a busy Saturday; getting more intimate with my leaky German. Link to comment Share on other sites More sharing options...
Mort Posted April 27, 2012 Report Share Posted April 27, 2012 Good luck Link to comment Share on other sites More sharing options...
