Golfy_101 Posted April 24, 2012 Report Share Posted April 24, 2012 Hi I have just joined and I've got a 1.4 16v mark 4 golf and my speedo not working I was told a fuse but sat there and checked the lot! Not blown then a sensor near gear box n replaced that still not working my miles counter is not working either but rev n other dials r any ideas welcome Link to comment Share on other sites More sharing options...
shark_90 Posted April 24, 2012 Report Share Posted April 24, 2012 Ideally you need to have the car looked at by someone with a diagnostic tool such as VCDS, you can check the vehicle speed in many different control modules (Engine ECU, ABS ECU and Instruments) and see if they match up. If they all show a speed, then you can assume that your instrument cluster is broken and replace that. If they all show 0, then you have a speed detection problem which you can then attempt to trace. Link to comment Share on other sites More sharing options...
