Mrdeli Posted July 22, 2012 Report Share Posted July 22, 2012 I was hoping to upgrade the speakers in my Q5. Originally I followed a few A4 threads presuming that they would be much the same. After removing the front door trim I found out that the mid range speakers in the door are around 21cm wide - pretty unusual. Can anyone suggest a way forward. I was wondering whether sourcing original equipment q5 B&O speakers may be the best option? The sound package in my car is the Audi Sound system - I think this is a mid way system between the standard system and the B&O system. Thanks. Mark. Link to comment Share on other sites More sharing options...
ChrissyR Posted July 22, 2012 Report Share Posted July 22, 2012 You'll have a hard time fitting B&O as its more than just the speakers involved. Link to comment Share on other sites More sharing options...
Mrdeli Posted July 23, 2012 Author Report Share Posted July 23, 2012 You'll have a hard time fitting B&O as its more than just the speakers involved. I just meant to replace the front door mid range speakers with B&O ones. Link to comment Share on other sites More sharing options...
Mo-S3 Posted July 31, 2012 Report Share Posted July 31, 2012 An expensive and not worth the money upgrade. Suggest you go with some 20cm quality aftermarket speakers and have some spacer rings made from mdf and retain the orignal grille. will sound much better than just changing the speakers to b&o ones. just watch for the mounting depth as you dont want the window to smack the magnet on its way down and shatter into a gajillion pieces Link to comment Share on other sites More sharing options...
Mrdeli Posted August 3, 2012 Author Report Share Posted August 3, 2012 An expensive and not worth the money upgrade. Suggest you go with some 20cm quality aftermarket speakers and have some spacer rings made from mdf and retain the orignal grille. will sound much better than just changing the speakers to b&o ones. just watch for the mounting depth as you dont want the window to smack the magnet on its way down and shatter into a gajillion pieces Sounds good advice. Would you be able to recommend a 20cm speaker? Thank you, mark Link to comment Share on other sites More sharing options...
