2feezy
Mmi is powerless on my 2005 a8l the display is blank all related systems are down
4 posts in this topic
I started having problems at first with static in the radio if it rained or if I went to a car wash but on and off but now it have completely given out the display is stuck in the upright position and it seems no power is getting to it I have removed the center console took apart the MMI system took out the circuit board cleaned it and the buttons and put it all back together but no luck still. coud it be that I now need a new board? thanks for any help
More likely that water has fried something else.
A scan with VAG-COM should identify the culprit. Then A8Parts can help.
Would have to be a pretty powerful car wash or rain storm to affect the MMI panel. As suggested it is more likely to be a fault elsewhere, the main locations in the A8 for MMI are the left of the boot, under the passenger floor on a RHD car with phone and in and behind the glovebox for CD changer and MMI controller.
I would suggest the AMP in the boot.
Or maybe the radio module?
My MMI was being affected by water ingress on my PF D3, never got an explanation from the garage as to the source.
