ronk Posted January 24, 2013 Report Share Posted January 24, 2013 (edited) My battery has just died! The new battery is being collected tomorrow and I' m going to change it. Is there anything I should watch out for? I am a bit worried about the car loosing its marbles due to a disconnect! Also there is a foam rubber trunk in front of the battery, does this slide up and does it re locate after battery installation? Thanks! A4 3.0 Diesel Quattro Edited January 24, 2013 by ronk Missed some important info! Link to comment Share on other sites More sharing options...
DanG Posted January 24, 2013 Report Share Posted January 24, 2013 I'd be inclined to leave the current battery in place, even if it's really flat, overnight to stop alarms going off etc. Also have your radio code handy as you might need it when the power goes back on. Finally I am sure it's a case of attaching negative first and the positive when firing he new battery, but it'll probably come with a few instructions. Link to comment Share on other sites More sharing options...
Booster Posted January 24, 2013 Report Share Posted January 24, 2013 Other way round Dan!! Disconnect earth lead first, reconnect last. Link to comment Share on other sites More sharing options...
ronk Posted January 24, 2013 Author Report Share Posted January 24, 2013 Other way round Dan!! Disconnect earth lead first, reconnect last. It saves making a lot of sparks this way!! I have seen in the info supplied with the car that the sat nav is PIN coded at first installation then after a power off and subsequent power on, the system looks for the code and if it identifies that the unit is fitted to the same vehicle it re initialises. Link to comment Share on other sites More sharing options...
cruiser647 Posted January 24, 2013 Report Share Posted January 24, 2013 Sounds about right for the radio code. Hope you are strong - those batteries are chuffin gheavy having to heave them up and out of the engine bay! Link to comment Share on other sites More sharing options...
DanG Posted January 25, 2013 Report Share Posted January 25, 2013 Other way round Dan!! Disconnect earth lead first, reconnect last. D'oh! When I park up the old car I always take of the positive to store...! Link to comment Share on other sites More sharing options...
ronk Posted January 26, 2013 Author Report Share Posted January 26, 2013 The reason behind takiing the -ve off first is to avoid sparks if the +ve is being removed and the spanner touches the grounded (-ve) parts of the vehicle. I am going to get help lifting the batteries ! I had an op on my neck some years ago and dont want any more damage! Link to comment Share on other sites More sharing options...
ronk Posted January 26, 2013 Author Report Share Posted January 26, 2013 I got a battery (Bosch 80ah) from Europarts - 4year warranty and £80 - I assume it has the vent hole on the RH side but I've not checked yet. Its way to cold to be out there today! Link to comment Share on other sites More sharing options...
ronk Posted January 30, 2013 Author Report Share Posted January 30, 2013 Update:- The clamp had an allen socket (6mm) and the bolt is captive - remove and slid to the port side and remove the battery. After conection the DSC indicator stayed on - drive 20 meters and it seems to re calibrate itself. Both keys require linking - sitting in the car press unlock for a few seconds and the indicators flash. As a footnote - Audi main dealer wanted to charge £120 for the battery and One hour @ £88 to fit (£250 total) It took two of us who have not fitted an battery int a audi before - so we didnt know what had to be remved - 30mins to fit and £80 for a Bosch battery! Link to comment Share on other sites More sharing options...
Twinspark Posted January 30, 2013 Report Share Posted January 30, 2013 I've done a shuffle with jump leads in the past so I didn't re-set all the electrics. I believe you can get a little gadget that does that for you, but I've never bothered getting hold of one. Link to comment Share on other sites More sharing options...
ronk Posted January 30, 2013 Author Report Share Posted January 30, 2013 I've done a shuffle with jump leads in the past so I didn't re-set all the electrics.I believe you can get a little gadget that does that for you, but I've never bothered getting hold of one. I suppose its not a job you have to do every day! Link to comment Share on other sites More sharing options...
