kev13 Posted March 29, 2013 Report Share Posted March 29, 2013 got abit of a problem with my 2.8 my oil light coming on only so much of the silly buzzer sound i can take the light will come on when i have done about 10 miles with out fail even if the car has been running for about 15 mins on the morning its -8 to +1 here on the morning. i can even just jump in it on the morning and it will still can on more or less at the same point i have seen this is a common problem when looking even with the 2.8 passat but no one says how there sorted it only some people put high pressure oil in seen something about the cluster can be the problem ? i have did the following oil level is on the max changed the oil pressure sensor cleaned oil pump out was full of bits and sump pump been checked all ok fitted new pump got it cheap off a mate thinking old one may have been temperamental new oil and filter 5w-30 fully syn put some engine flush oil through it Link to comment Share on other sites More sharing options...
Ian_C Posted March 29, 2013 Report Share Posted March 29, 2013 Oil pressure sensor or oil level sensor? Like you, I was finding the level sensor warning kept coming on longer journeys before it was then staying on permanently despite showing max on dipstick, so I replaced the oil level sensor when I changed the oil earlier this month. Its easy to access, but [on mine] you cannot change it without changing the oil. Part wasn't cheapest though.... Link to comment Share on other sites More sharing options...
kev13 Posted March 29, 2013 Author Report Share Posted March 29, 2013 dont have a oil level sensor on it only a pressure sensor/switch have now found some people now try putting 10w-40 or 10w-50 in then never say if that sorts it Link to comment Share on other sites More sharing options...
snapdragon Posted March 29, 2013 Report Share Posted March 29, 2013 dont have a oil level sensor on it only a pressure sensor/switch I doubt it, remove the plastic tray and look at the sump, there should be a oil level sender with electrical connection. 46 Link to comment Share on other sites More sharing options...
kev13 Posted March 29, 2013 Author Report Share Posted March 29, 2013 I doubt it, remove the plastic tray and look at the sump, there should be a oil level sender with electrical connection.46 [ATTACH=CONFIG]48200[/ATTACH] it dont have one have allready got the plastic tray off the early ones never had them from what i have read there only have the oil pressure sensor/switch Link to comment Share on other sites More sharing options...
