STANNER
taking the plunge
6 posts in this topic
Decided to buy a new 2013 satnav disc from Audi, is there a part no to make sure I get the latest disc,car is an 07 A6 avant le mans,also any other upgrades to consider, I believe the headlights can be set to tourist mode via vcds for driving in europe to save manually changing them,ie levers on headlights, Cheers guys
Welcome to TSN
Tell the dealer your reg and let them order it. If they feck up then they'll have to replace it.
It one of us tells you the code then you've still gotta order it from Audi and you won't get a refund from anyone on here if it's wrong.
Whilst my car is with Audi for warranty work, I asked if they would update my satnav as a gesture, they agreed, the update for MMI 3g HDD nav takes 8 hours! and should cost £320.00 does anyone know what the update contains?
Pixie dust and unicorn hoof clippings for that much :eek:
Also why the FECK would it take 8 hours??!! Or is that just a claim so Audi can justify the cost?
I would normally agree, however, this is being done FOC................
Completed so far;
• Carried out removal of gearbox and clutch/flywheel stripped and inspected, compared to new pressure plate and found clutch finger springs dropped in height – cause of judder. Carried out replacement of complete clutch and bolts. Torqued and put gearbox back in. Road tested and all OK
• Replacement of two front tyres (Dunlop)
• Phase 1 of the 3 phased (8 hour) sat nav update!
• A road test for rattle which Mark believes could possibly be from the dash rather than the door – They are carrying out second road test after update (unfortunately the car has to stay plugged in to a computer on a ramp until update is completed)
Who knows, perhaps there is magic involved..................
