blackfatcat Posted July 3, 2013 Report Share Posted July 3, 2013 Hi - went to start car on Monday evening and discovered sidelights had accidentally been left on from the night before. Dead battery/no lights on dash/won't start (naturally)! A friend tried jumping it last night but no luck either. Going to take the battery off and try charging it on 6 amp charger indoors tonight. If it does work, I understand the electrics (locking/radio etc) may act a little weird to start off with...however, if the battery doesn't charge and a new battery doesn't resolve the problem, what to look at next other than the alternator ? This is the first car that I have owned that has extensive electrics - others have been 1996 reg and prior 'simple' cars so easier to diagnose/fix! Link to comment Share on other sites More sharing options...
Luke Posted July 3, 2013 Report Share Posted July 3, 2013 Probably due a new battery if its 11 years old. Link to comment Share on other sites More sharing options...
blackfatcat Posted July 3, 2013 Author Report Share Posted July 3, 2013 Thanks Luke. Once I get the battery off tonight we'll try and find a date code on it. If it's really old, obviously it will just be sent to the dump and a new one bought. My question is - if the battery is a bit newer, is it even worth the hassle of trying to charge it when it is clearly totally dead right now! And also, where to start checking next, other than getting the alternator tested.. Link to comment Share on other sites More sharing options...
pingpongpo Posted July 3, 2013 Report Share Posted July 3, 2013 Its always worth trying to charge the battery, it must have been ok recently at some point? The only other things to look for are parasitic drains on the battery such as after market alarms, radios etc which might be drawing current even though they are supopsedly switched off/ Link to comment Share on other sites More sharing options...
Mook Posted July 3, 2013 Report Share Posted July 3, 2013 Thanks Luke.Once I get the battery off tonight we'll try and find a date code on it. If it's really old, obviously it will just be sent to the dump and a new one bought. My question is - if the battery is a bit newer, is it even worth the hassle of trying to charge it when it is clearly totally dead right now! And also, where to start checking next, other than getting the alternator tested.. Charge the battery and then get it tested to see if it's holding its charge. If it's as old as the car, then you may as well replace it - it'll be about £70-80. Link to comment Share on other sites More sharing options...
