neilm Posted June 5, 2014 Report Share Posted June 5, 2014 HI Guys, first post here so be nice please.. I have bought the a6 2005 fsi 3.2 quattro today, I think form what I have read (first audi) it is a mmi high system , but when selecting sat nag, it states needs navigation disc, nothing for tv . I have read lots of threads but nothing specific to this model, and a as a result just wondering the best/cheapest route to resolvea:sat nav,b: tv .. c: Linking into the bluetooth of phone Will it be costly.. attached hopefully pic of display any help greatly appreciated.. cheers neil Link to comment Share on other sites More sharing options...
Twinspark Posted June 5, 2014 Report Share Posted June 5, 2014 Suspect the Bluetooth will be the silly non-standard version that was only properly supported by Nokia and perhaps Samsung - it certainly was on VWs of that era. Link to comment Share on other sites More sharing options...
neilm Posted June 5, 2014 Author Report Share Posted June 5, 2014 Hi Twinspark, thanks for the reply. i have a samsung s3 though guess that will make no odds..?? Link to comment Share on other sites More sharing options...
Twinspark Posted June 5, 2014 Report Share Posted June 5, 2014 Assuming the module is there, then you should be fine. It works using the rSAP profile - which is actually much better than the standard bluetooth profile, but not widely supported. Link to comment Share on other sites More sharing options...
Booster Posted June 5, 2014 Report Share Posted June 5, 2014 The tv won't work as it is only receives an analogue signal which is no longer broadcast. There are lots of websites that will sell you a nav disc including eBay. You need to pair your phone within one minute of the ignition being switched on (and I think the drivers door must be closed - I had the same system in a 2005 A3). Link to comment Share on other sites More sharing options...
neilm Posted June 6, 2014 Author Report Share Posted June 6, 2014 (edited) hi guys thanks for the advice, does anyone know what disc it is that I need ,? also how do I pair the phone, or is it rtfm? Edited June 6, 2014 by neilm 1 Link to comment Share on other sites More sharing options...
neilm Posted June 6, 2014 Author Report Share Posted June 6, 2014 Ps to clarify. It is a 2005 model.. Boister. Thanks fir reply. Do you know pairing procedure. As nothing in manual.. bar stuff on p127. But not pairing . Do you recall your steps. Is it with mmi or with the inbuilt phone ypu do this...... Link to comment Share on other sites More sharing options...
neilm Posted June 6, 2014 Author Report Share Posted June 6, 2014 Guys is it this set I need please AUDI GENUINE PART NUM.: 4L0 998 961 F/W 55.7.0 Link to comment Share on other sites More sharing options...
Booster Posted June 6, 2014 Report Share Posted June 6, 2014 Search for the car from your phone's Bluetooth menu within one minute of turning the ignition on. You should then get a code request on your phone. The code to pair the phone to the car is either 1234 or 0000. Link to comment Share on other sites More sharing options...
neilm Posted June 6, 2014 Author Report Share Posted June 6, 2014 Cheers booster. anyone advise on the nav / mmi disc situ please Link to comment Share on other sites More sharing options...
neilm Posted June 6, 2014 Author Report Share Posted June 6, 2014 booster, I got it too pair, but then how do you access your numbers in the phone, still seemed like options were not there for phonebook etc etc Link to comment Share on other sites More sharing options...
Booster Posted June 6, 2014 Report Share Posted June 6, 2014 Phone book takes awhile to download for the first time. Once it does, it is there. You can also add numbers you use regularly to the directory. If you have a button that looks like a bloke saying something on the steering wheel you can add voice dialling. Maybe a quick RTFM might help!! Link to comment Share on other sites More sharing options...
neilm Posted June 7, 2014 Author Report Share Posted June 7, 2014 cheers fella, appreciate your help, I did have a look and noted that, actually the other half pointed that out too me.just once it paired , I had no further options than before when I started, so maybe it was just taking time, while it produce the message, reading sim card once connection established , as that was all that I seen happening ? but then that is happening when i turn on usually and goto phone,as I think there must be an old sim card in the in car handset, should I remove that do you think or leave it in. cheers agin for your help... Link to comment Share on other sites More sharing options...
cruiser647 Posted June 7, 2014 Report Share Posted June 7, 2014 I'd have thought you'd need to remove the old SIM, so it only uses your phone? Sat Nav - You should be able to buy either a Western Europe or a UK DVD on eBay. The drive is in the boot (usually) on the passenger side, behind a panel. Link to comment Share on other sites More sharing options...
neilm Posted June 7, 2014 Author Report Share Posted June 7, 2014 hi Cruiser, yeah I have a couple of modules in there , top two shelves in the rack, can't see where you would put a dvd in though. I was more trying to get the specific version I need based on the shot of my system , inc the mmi update? Link to comment Share on other sites More sharing options...
cruiser647 Posted June 7, 2014 Report Share Posted June 7, 2014 hi Cruiser, yeah I have a couple of modules in there , top two shelves in the rack, can't see where you would put a dvd in though. I was more trying to get the specific version I need based on the shot of my system , inc the mmi update? Ahhhh, be careful, VERY careful with the MMI update. Haven't done it myself on my 8, but I know you need to do it carefully. Don't think I can emphasise that emough! Just type A6 Sat Nav DVD into eBay and you'll get loads of originals pop-up for all dates. I could do with a newer one than 2004....... Link to comment Share on other sites More sharing options...
