drumstick
Parking break won't release
5 posts in this topic
Hi all. car is a 2005 passat B6 model.
I have an intermittent problem where the parking break motors are making a noise (or at least one is) but the break won't release. Any advise will be greatly recieved.
I have taken matters in to my own hands and removed the fuses, in my haste I removed all fuses which included one that power the ABS. I gave replace those and just left out the 20amp one for the motors in the calipers. Another problem I have now is the the ESP light is permanently on. The ABS works fine.
Is there a method is resetting the ESP.
Thanks for any help you can give me.
The ESP is probably on from the ABS fuse being removed.
You may need a cheap fault reader to reset the warning light, or chase the issue further.
As for the BRAKE motors, I have no knowledge of the car or this syatem, so can't help.
Do you use the parking brake button to put it on and off?  Or just pull away so it 'flips' off?
Maybe the caliper motor is just knacked?
I mostly use the switch to release the brake and to apply it. But I do use the auto-hold a lot. Well I did...... lol
