avantissimo Posted October 10, 2014 Report Share Posted October 10, 2014 Hi all, tyre pressure monitor went off on the car today so decided to check the tyres. Data panel on door says 44psi on the front and 48psi on the rears. This seems very high so I phoned the stealer to see what they said. They said 33psi on the front and 30psi on the rear. I'm totally confused as I check the doors panel a dozen times to check. The car is a 2012 current model edition c7 A6 Avant 3.0tdi Quattro black edition with the Pirelli 20" tyre and wheel combination - tyre dimension 255x35xr20. Can anyone with this car or knowledge of it confirm what your thoughts are? Many thanks. Link to comment Share on other sites More sharing options...
Tipex Posted October 10, 2014 Report Share Posted October 10, 2014 (edited) 33/30 is way too low for a heavy lump like the 3.0. Stick with what the door panel says, I would imagine 44/48 is the fully loaded 'max pressure' though, there should be a slightly lower option too I'd have thought. Edited October 10, 2014 by Tipex Link to comment Share on other sites More sharing options...
patently Posted October 10, 2014 Report Share Posted October 10, 2014 I'd agree with T and stick closer to the door pressures. How does the car handle? Do the tyres grip properly? How even is the tread wear? Link to comment Share on other sites More sharing options...
chasdrury Posted October 10, 2014 Report Share Posted October 10, 2014 (edited) Iirc our bitdi avant is 44/42 for normal loads Edited October 10, 2014 by chasdrury Link to comment Share on other sites More sharing options...
Ian_C Posted October 10, 2014 Report Share Posted October 10, 2014 I phoned the stealer to see what they said. They said 33psi on the front and 30psi on the rear. What the f***?! Did you speak to the contract cleaner? Or one of the receptionist girls? 30 is comical! Go with the door panel everytime. Take the advice of the Audi factory door sticker rather than your franchise dealer..... 1 Link to comment Share on other sites More sharing options...
avantissimo Posted October 10, 2014 Author Report Share Posted October 10, 2014 The tyre wear is good. I've done 14,000 since new and the wear is very good. Quattro tends to mince tyres but this is the most ive ever had out of a set. The fronts have worn a little more than the rears but its even wear. Ride is not punishing either. Although it has the lower s line sus (30mm lower not the 20mm sport version) the ride in this c7 compared to the 19"s on my previous c6 avant is worlds apart as that car would snap your spine going over a leaf. As for grip....yes its a big car but it just holds the road like a weapons grade vice. No complaints at all. As for the stealer they had to ring me back after talking to a mechanic which is where those silly pressures came from. So as suggested I will stick to door panel advice. There is a slightly lower psi for a lighter load so I'll be using that. Thanks for all comments. As usual stealer advice is nothing but guff. Link to comment Share on other sites More sharing options...
patently Posted October 11, 2014 Report Share Posted October 11, 2014 Sounds like you had the right pressures Link to comment Share on other sites More sharing options...
Lussac Posted October 11, 2014 Report Share Posted October 11, 2014 Interesting reading this. Although not the same car (my car is a Jaguar XF 3 litre diesel) the wheel/tyre size is the same and the sticker in the door says 32 psi all round or 34 psi all round if laden or high speed motorway. The XF must be somewhat lighter than the Audi I know that someone on the Jaguar forums ran a set of Dunlop Sport Maxx at 36/37 psi and there was noticeable wear around the centre of the tread so those pressures were too high. Link to comment Share on other sites More sharing options...
Scotty Posted October 11, 2014 Report Share Posted October 11, 2014 (edited) On the A4 (so may/may not be the same for the A6), Audi recommend you run at max load pressures all the time .... unless you prefer a softer ride. Confusingly this information is not on the door sticker but only in the manual. So for me (running 19's) I'm 39/44. can;t say I'm surprised by the Audi comment Was it sales or technical that said that? I always check my tires regardless of who fits them as they've been wrong so many times. Edited October 11, 2014 by Scotty Link to comment Share on other sites More sharing options...
cruiser647 Posted October 11, 2014 Report Share Posted October 11, 2014 My 19"s are on 34 front & 32 rears I think. That's on 245 40's. But mine is a diesel A8 (54 plate) so still a heavy beastie. I have never found quattros to mince tyres. They have always been even over the axles, but front go quicker. I get higher mileage out of quattro fronts than I ever did on the Bora. Link to comment Share on other sites More sharing options...
