plip63 Posted November 17, 2014 Report Share Posted November 17, 2014 I have recently changed the HG on my vw mk4 golf after loss of coolant, but now it wont start. I have tried a tow start but nothing. the tandem pump is primed with the fuel coming out of the return hose, all connections were cleaned and put back but it still wont fire. any help would be greatly appreciated. Mk4 golf 2001 pd 130 engine. Link to comment Share on other sites More sharing options...
E-bmw Posted November 17, 2014 Report Share Posted November 17, 2014 If you have just changed the HG, I would recommend removing the rocker cover & checking all is well & it is timed correct mechanically. Is it petrol or diesel? Link to comment Share on other sites More sharing options...
plip63 Posted November 17, 2014 Author Report Share Posted November 17, 2014 diesel, everything has been checked and double checked, but it still wont start. ive read that the ecu records a fault code if the injector plus is removed, would this cause it untill its cleared? thanks for the reply. Link to comment Share on other sites More sharing options...
E-bmw Posted November 18, 2014 Report Share Posted November 18, 2014 If the battery was disconnected at the start of the job & not reconnected until the end (as you should on all such intrusive jobs) then, no. If everything has been connected properly, if there are no shown fault codes, that only leaves something physically fundamental such as fuelling or timing, so you need to get the spanners out & re-check everything again. Sorry. Link to comment Share on other sites More sharing options...
