tmh-007
VW Passat Estate 2L TDI Highline (59) Window Help
2 posts in this topic
I have a 59 plate VW Passat Estate 2L TDI Highline and today I discovered my back window doesn’t work, after further investigation I have discovered the mechanism still works and the glass stays up, until you lower it by hand. The glass then sits on the mechanism and closes electrically.
Anyone have any advice on how to fix.
Thanks
If you remove the door card you will find the window has come out of its fixture on the mechanism, they are normally just wedged in with a rubber sleeve of some description.
