Adam Smith
RNS 315 Bluetooth & reverse cam problems
3 posts in this topic
Hi !
i recently had an RNS 315 fitted to my VW caddy . It's the model with built in Bluetooth and dab .
Bluetooth works to a degree in that it sees my phone and enables me to make and receive calls but it won't let me stream music . Now and again it show the iPod icon and display track info on screen so it is seeing it but just no audio . Most of time however it won't even do that it just displays no medium available.
I also had my installer try and fit reverse camera but to no joy . When in reverse a black screen just shows with 'is it safe to move ' or something along those lines displayed .
any ideas what could be causing these issues or better still any specialist in the north west / Liverpool area that can help?
thanks .
It was not one of those, but I bought a similar system from iceboxauto in Fazakerley for my e39 a few years ago, they may be able to help as most are pretty similar.
It will need programming by Vag Com. You can get a dealer to do it or bye the Ross tech lead and software.
I know it sounds a bit daft but you need to tell the car (using the software) that it has the equipment fitted.
