Sorin cocan
Reseting my MFD2
4 posts in this topic
Does anyone know how I can reset my MFD2 SAT NAV after an bad software update my radio doesn't work anymore, thanks
IIRC to reset it you press "eject" key along with one of the "arrow" keys.
You could also try disconnecting the battery.
To resolve the issue you.may need to update the firmware again.
Just try both a see what happens.
I came across the following;
To do a factory Re-set, first press the INFO button (at the bottom left of the MFD2)
Then press SYSTEM SETTINGS to open the main menu for system settings.
In the top right hand corner will be a FACTORY SET button. Pressing that resets the unit to factory default
