sdahlheimer Posted March 7, 2004 Report Share Posted March 7, 2004 I have a 1969 911e, with mfi, that usually starts up easily, will idle till the cows come home. If you drive it as little as quarter mile it stops running. Like it runs out of gas. car has less than 50 thousand original miles. I checked the fuel pressure from Pump was 25 lbs. Out of fuel filter about 11lbs. Replace filter got same problem. Any suggestions? This car is New to me; never have a porsche before. Am determined not to have to take to a dealer. Any help would be appreciated. Link to comment Share on other sites More sharing options...
wgeg Posted November 18, 2004 Report Share Posted November 18, 2004 steve, you may be having a problem in you fuel distributor. Or it may be electrical, your coil could be breaking down. Good Luck and stick with doing your own repairs as much as possible. However do get a good repair manuel and learn your car. Link to comment Share on other sites More sharing options...
shao_khan Posted November 18, 2004 Report Share Posted November 18, 2004 I wouldnt visit a dealer, but check through the porsche post and stuff liek that, there are some very good independent garges around, i know a couple in the london area that a guy at work uses with his '72 targa. Link to comment Share on other sites More sharing options...
Jonster Posted November 24, 2004 Report Share Posted November 24, 2004 check the fuel delivery rate, the actual volume of fuel it can pump in a set period of time. Sounds to me that you have a fuel starvation issue, where the pump is able to maintain pressure when there is a demand for very little fuel flow, but when there is a demand for a greater quantity of fuel, its unable to keep up. It would also be worth taking the fuel sender from the fuel tank and having a look in there, as it could be that the tank is rusty inside, which could be clogging the fuel strainer, damaging the pump and possibly clogging your fuel filter (even though its new) Did you cut open the old fuel filter? if so, how did it look in there? Link to comment Share on other sites More sharing options...
