graeme86 Posted July 26, 2004 Report Share Posted July 26, 2004 Does anyone know if there is a speed warning buzzer that can be activated above a certain speed built into R32 dash (maybe used in Japan????? - speed buzzer sound if speed exceeds 120kmh????) Link to comment Share on other sites More sharing options...
Foggy Posted July 26, 2004 Report Share Posted July 26, 2004 Can't this be done on the R32 DIS ? I know it can on the A3 / S3 Link to comment Share on other sites More sharing options...
graeme86 Posted July 26, 2004 Author Report Share Posted July 26, 2004 Any idea of the VAG-com codes that would apply? Link to comment Share on other sites More sharing options...
Foggy Posted July 26, 2004 Report Share Posted July 26, 2004 It's not a VAG-Com thing. On the S3 you just push a button on the DIS when you reach the speed you want it to warn you at, from then on it will warn you whenever you hit that speed. Actually you can set it to warn you at two different speeds. Link to comment Share on other sites More sharing options...
Hopsta Posted July 26, 2004 Report Share Posted July 26, 2004 That will only set it temporarily for that journey only. With keys in the ignition on Posn 1 press the clock button (clock etc should now show up) Press it again for 2 secs and you will see the DIS show speeds, use the DIS toggle on the right hand stalk to change it. Once you have it set to the desired speed then leave it a few secs and hey presto its set ! Graham Link to comment Share on other sites More sharing options...
graeme86 Posted July 26, 2004 Author Report Share Posted July 26, 2004 Foggy, which button do you press on DIS? Link to comment Share on other sites More sharing options...
Hopsta Posted July 26, 2004 Report Share Posted July 26, 2004 Same button you use to set your clock Link to comment Share on other sites More sharing options...
graeme86 Posted July 27, 2004 Author Report Share Posted July 27, 2004 I tried out the above. I only have the half size display in R32. The clock button (in tacho) does not push in, only turns left or right to set hours and minutes display. Does anyone have a full size display (sat nav) to try this on? Thanks Link to comment Share on other sites More sharing options...
Bradmax57 Posted September 1, 2004 Report Share Posted September 1, 2004 [ QUOTE ] That will only set it temporarily for that journey only. With keys in the ignition on Posn 1 press the clock button (clock etc should now show up) Press it again for 2 secs and you will see the DIS show speeds, use the DIS toggle on the right hand stalk to change it. Once you have it set to the desired speed then leave it a few secs and hey presto its set ! Graham [/ QUOTE ] It brings upto the mph logo with a number 2 next to it, does this mean I can set another speed? if so how Link to comment Share on other sites More sharing options...
Hopsta Posted September 1, 2004 Report Share Posted September 1, 2004 You can only set 1 temporary ie and 1 permanent as described above. Temp one is set per journey by pressing the left hand button (under clock) at the desired speed. Link to comment Share on other sites More sharing options...
Bradmax57 Posted September 1, 2004 Report Share Posted September 1, 2004 [ QUOTE ] You can only set 1 temporary ie and 1 permanent as described above. Temp one is set per journey by pressing the left hand button (under clock) at the desired speed. [/ QUOTE ] I see many thanks Link to comment Share on other sites More sharing options...
Mollox Posted September 1, 2004 Report Share Posted September 1, 2004 Personally I find it really annoying. When I first got the car I accidentally set it to about 35 and couldn't be bothered to find out how to stop it. So that journey (urban-ish roads) it was going off every minute. #2 has always been set at 135 so if Liz hears the beep she checks to see if i have washer fluid and if not she knows instantly i'm being a very naughty boy Link to comment Share on other sites More sharing options...
Bradmax57 Posted September 2, 2004 Report Share Posted September 2, 2004 [ QUOTE ] Personally I find it really annoying. When I first got the car I accidentally set it to about 35 and couldn't be bothered to find out how to stop it. So that journey (urban-ish roads) it was going off every minute. #2 has always been set at 135 so if Liz hears the beep she checks to see if i have washer fluid and if not she knows instantly i'm being a very naughty boy [/ QUOTE ]LOl Ill have to try that Link to comment Share on other sites More sharing options...
Daz Posted September 2, 2004 Report Share Posted September 2, 2004 [ QUOTE ] When I first got the car I accidentally set it to about 35 and couldn't be bothered to find out how to stop it. So that journey (urban-ish roads) it was going off every minute. [/ QUOTE ] LOL I did the same when I picked up my S3. Didn't want to stop driving and get the manual out to find out what I'd done. Link to comment Share on other sites More sharing options...
graeme86 Posted April 24, 2005 Author Report Share Posted April 24, 2005 I have resurrected this from the dead for a further update. I think if you code the dash country code to "Saudia Arabia" then you get a continuous buzzer at above 125 kmh. Link to comment Share on other sites More sharing options...
Disco300 Posted May 31, 2005 Report Share Posted May 31, 2005 Is there anything like this on the B5 Passat ... is the facility available. Same as "graeme86" my clock button doesn't press only turns each way to set the hours or mins! Link to comment Share on other sites More sharing options...
