sschlesinger Posted March 11, 2003 Report Share Posted March 11, 2003 I had an Alpine stereo installed in my 2000 Jetta. The installer followed Tech Bull 99-01 and did not connect the K-Wire to avoid problems with the scan tool. I had the engine check light come on and took it to the dealer. They said they couldn't diagnose it because the K-Wire was not grounded. Does this mean that as long as the Alpine stereo is installed, the diagnostics system can't be used? Any advice would be appreciated. Link to comment Share on other sites More sharing options...
Silverman Posted March 25, 2003 Report Share Posted March 25, 2003 Hi, New VW radios are ''diagnostic-capable''. This means that the diagnostic system talks to the radio to detect faults and change settings. The ''K-Line'' on these new diagnostic-compatible radios happens to be on a pin previously used by VW/Audi radios for +12V. Therefore, if a third-party adapter-cable is used to install an aftermarket radio it can result in the K-line pin being directly to 12V. This tends to cause damage to dealer diagnostic tools and can be very costly for them. If the installer followed the TSB then the K-Line should not be connected to the radio. This should not cause any problems to the rest of the diagnostic system - the only noticeable change should be that the radio can no longer be programmed/diagnosed. Did the dealer actually connect the diagnostic tool to your car? If they just refused to diagnose it, as many dealers will if the car has an aftermarket radio fitted, you could always buy your own diagnostic tool. See ''VW Market Place'' forum. Regards, Link to comment Share on other sites More sharing options...
