Lagoo
TVR Speed 12
10 posts in this topic
Umm!
Heres the Spec:
Engine: 7730cc 90 degree V12 Steel block, aluminium heads, 4 valves per cylinder Dry Sump, 12.5:1 compression ratio
Power: 800 bhp at 8250 revs
Torque: 650 lbs/ft at 5750
Weight: 1000kg
Chassis: Space frame with integral rollover and side impact protection.
Brakes: Front - 378mm ventilated with 6 pot callipers
Rear - 273mm ventilated with 4 pot callipers
Wheels: Front - 11x18, 285/35 tyres
Rear - 13x18 345/35 tyres
Christ!! blush.gif .. imagine that comming up behind you and into your mirror.. quick bowel movement and pull over grin.gif
It is indeed a beast!!! You have more chance of a Cerbera Sp12 coming up behind you!! Problem is trying to get one... Peter Wheeler vets each customer shocked.gif
</font><blockquote><font class="small">In reply to:</font><hr />
vets??
as in "vets in practice?"
Dave what do you reckon to the tyre sizes shocked.gif How the hell would you source one of those.... more importantly how much would they cost shocked.gif
Must have them specially made I would imagine blush.gif...
cost..; I would guess at £450 a tyre??
Michelin Pilot Sport - £330.30 per tyre from mytyres.net inclusive of VAT and Delivery
I read old Wheeler did not want to sell them becasue they are just too powerful.
In Evo magazine they stated that they still havent confirmed the exact power rating and the Chairman doesnt find it at all practical infact says "completely pointless as a road car" Strong words from a power hungry Sports car fanatic
Article also mentioned that they had a Speed 12 on a dyno rated 1000bhp and it snapped before a complete reading was taken.
Quote "I knew within 300 yards that it was a silly idea.Over 900bhp in a car weighing just over a ton is plainly ridiculous on the road. It doesnt matter what gear you are in ,you just couldnt get to use the power"
"If someone comes to us and still wants to buy one I can usually talk them out of it,given time"
These are the spect which i have found, sorry about the mess. xxx
Year 2000 Origin Not Available
Make TVR Base Price $245 000 USD
Model Cerbera Speed 12 Production Not Available
Engine & Transmission Body / Chassis
Position Not Available Drive Wheels Front Engine
Configuration V12 Curb Weight 1000 kg / 2205 lbs
Valvetrain 4 valves / cyl Length 4300 mm / 169.3 in
Displacement 7730 cc / 471.7 cu in Width 1960 mm / 77.2 in
Power 596.6 kw / 800.0 bhp @ 7250 rpm Height 1100 mm / 43.3 in
Torque 881.3 nm / 650.0 ft lbs @ 5750 rpm Wheelbase 2642 mm / 104.0 in
HP / Liter 103.49 bhp per litre Body / Frame Glass Fibre
HP / Curb Weight Front Brakes Vented Discs /wo ABS
Front Brake Size 378 mm / 14.9 in
Front Tires F 285/35ZR18
Rear Tires R 345/35ZR18
Performance
Top Speed 386.2 kph / 240.0 mph 0 - 60 mph est 3.0 seconds
Actually the TVR Cerbera speed 12 which looks like a Cerbera and the TVR speed 12 GT acttually Broke the DYNO (rolling road thingy) and just before it broke it it read just over 1000BHP! grin.gif
