dq1 Posted March 20, 2005 Report Share Posted March 20, 2005 Was driving my A3 1.8T yesterday when the engine management light came on. I ran Vag-com on my car and got the following code: 17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!) P1297 - 35-10 - - - Intermittent Can anyone explain the likely cause and how easy it is to fix? Link to comment Share on other sites More sharing options...
Paul Posted March 20, 2005 Report Share Posted March 20, 2005 could be a split or blown off hose, could be a failed DV passing. id clear fault and see if it comes back and check around your pipework. Link to comment Share on other sites More sharing options...
dq1 Posted March 20, 2005 Author Report Share Posted March 20, 2005 Cleared the codes and took the car for a 10 mile spin. No more errors. Will go check the pipework, thanx Paul-S3 Link to comment Share on other sites More sharing options...
dq1 Posted March 21, 2005 Author Report Share Posted March 21, 2005 Checked the pipe work and no immediate cracks or splits. Have booked the car into a garage to check the problem out. I've told them I will bring a print of the fault codes as my warranty dosen't cover cost of diagnosing! Link to comment Share on other sites More sharing options...
dq1 Posted March 29, 2005 Author Report Share Posted March 29, 2005 Drove up north at the weekend and after 200 miles the engine management light came back on. Ran Vag-com again when I got home and the same fault was recorded. Good job it's booked in on friday. Link to comment Share on other sites More sharing options...
