felixthecat1 Posted April 13, 2005 Report Share Posted April 13, 2005 [ QUOTE ] Tian - was that a "This is an advert, I'm Howard, and I want to prove that I'm young hip and trendy so that I can sell our products to the young" type comment?? Ok I'll stop calling you Howard from now on. Probably. [/ QUOTE ] No way dude, what ya chattin' guy? Is it cos I'm black? Link to comment Share on other sites More sharing options...
IanHo Posted April 13, 2005 Report Share Posted April 13, 2005 No, you just use the bucket with clean water in to clean the off the sponge, as the amount of dirt it picks up is unbelievable. Saying that no dirt got back on the car, but me sponge is now black. Link to comment Share on other sites More sharing options...
Tomk Posted April 14, 2005 Report Share Posted April 14, 2005 but if you are putting the sponge in the water , surly its just better to put some shampoo in the bucket and clean the car as normal ?? i do get the point of rinsing it off with the filtered water though... Link to comment Share on other sites More sharing options...
IanHo Posted April 14, 2005 Report Share Posted April 14, 2005 The shampoo gets mixed directly with the water and sprayed on to the car, so I assume is done in the correct ratios? Whatever it does, it gives a great finish. Link to comment Share on other sites More sharing options...
jnm008 Posted April 14, 2005 Author Report Share Posted April 14, 2005 how long do you spend spraying the filtered water on the car? Link to comment Share on other sites More sharing options...
Si_GTi Posted April 14, 2005 Report Share Posted April 14, 2005 Only a couple of minutes, just long enough to make sure that you spray the filtered water over all of the car. Start from the roof and work your way down the car over bonnet/boot (or hatch) and then sit back and watch it dry off spotlessly! Link to comment Share on other sites More sharing options...
Sparky Posted April 25, 2005 Report Share Posted April 25, 2005 Okay, just bought the refills. 10-use filter, and shampoo - £7. So doesn't seem bad value. My free filter that claims only 3 washes lasted 5 before it showed it needed replacing, although depends on your water hardness. Link to comment Share on other sites More sharing options...
Tomk Posted April 26, 2005 Report Share Posted April 26, 2005 were did you get the refils ? Link to comment Share on other sites More sharing options...
Sparky Posted April 26, 2005 Report Share Posted April 26, 2005 Halfords. Link to comment Share on other sites More sharing options...
CarMad Posted April 26, 2005 Report Share Posted April 26, 2005 I used it for a second time at the weekend and it seems even better than the first time. Wet it all first, did about a quarter of the car at a time rinsing as I go. Got talking for a second and looked back and the car was super clean and not a single water mark on it anywhere. Didn't even use the ionised water either. It really is petty darn good and really is worth a try for the more sceptical amongst us. Link to comment Share on other sites More sharing options...
Tomk Posted April 27, 2005 Report Share Posted April 27, 2005 mmm but is it really better than using the pressure washer, sprakig soap on it , sponge it then wet down with the presure washer again ?? Link to comment Share on other sites More sharing options...
a4tdi130 Posted April 27, 2005 Report Share Posted April 27, 2005 [ QUOTE ] mmm but is it really better than using the pressure washer, sprakig soap on it , sponge it then wet down with the presure washer again ?? [/ QUOTE ] Oh just go and buy one and try it Link to comment Share on other sites More sharing options...
Sparky Posted April 27, 2005 Report Share Posted April 27, 2005 [ QUOTE ] mmm but is it really better than using the pressure washer, sprakig soap on it , sponge it then wet down with the presure washer again ?? [/ QUOTE ] Yes!! It really does so something plain old car shampoo doesn't. Link to comment Share on other sites More sharing options...
Tomk Posted April 27, 2005 Report Share Posted April 27, 2005 ok you win ! ill buy one when i go past somewere ! pill probably need a longer hose now though lol Link to comment Share on other sites More sharing options...
apreading Posted April 27, 2005 Report Share Posted April 27, 2005 Got one in Tesco for £20 yesterday - will be trying it this weekend hopefully. I only bought it for the 'self dry' bit, but is it worth using it as a shampoo as well...? Link to comment Share on other sites More sharing options...
Tomk Posted April 27, 2005 Report Share Posted April 27, 2005 thats what im thinking .... tesco hey ??? mmm ill try there ! will post a full review with picts later Link to comment Share on other sites More sharing options...
Sparky Posted April 27, 2005 Report Share Posted April 27, 2005 The shampoo is what makes the difference. I actually had my pressure washer hooked up to the hose as well as the Flash Carwash (hozelock T splitter thingy) and used the pressure washer to clean the car and apply the soap (it has a soap attachment). Then used the Flash thing to perform the drying only function. It worked just as well. The soap obviously is doing the work. It also leaves a film on the car so when it rains, it all beads off nicely. The unit is worth getting - it does make it simpler, but when your car is covered in dirt then you need good water pressure to match that of a pressure washer to remove it. Otherwise, when you get that sponge on your paintwork, you'll add scratches. It takes about half the amount of time to wash my car now, and it looks much better after doing so. 1) Blast car with Pressure Washer to remove dirt. 2) Cover a section of the car in soap 3) Sponge it around 4) Wash it off with clean water 5) Apply "drying" water to it and move onto the next section If you don't like it, send it back. Link to comment Share on other sites More sharing options...
CarMad Posted April 29, 2005 Report Share Posted April 29, 2005 As Sparky says it really is that easy. I used it at the weekend with the soap and not the drying water ?!? And it still worked a treat, I was speaking to someone so didn't have time to take it off. It looked great and a leather never touched it, if I hadn't used it and seen it myself I wouldn't have believed it. It works better the second time I used it aswell don't be tempted to do the whole car in one go it doesn't work as well like that. Water, quick lather quarter at a time with the top first, then wash off each section as you do it, then the drying water all over. It comes up a treat. Link to comment Share on other sites More sharing options...
Tomk Posted April 29, 2005 Report Share Posted April 29, 2005 right went to the large tesco and sainsburys at lunch .... neither of them had it ! will have to stop somewere on my way home, thing woolys had one ! will try it tonight and tell you my oppinions ! Link to comment Share on other sites More sharing options...
jnm008 Posted April 29, 2005 Author Report Share Posted April 29, 2005 nice post I created , over 3000 views!! Link to comment Share on other sites More sharing options...
vagman Posted April 30, 2005 Report Share Posted April 30, 2005 Haven't tried the Flash product, but recently acquired a filter thingy from Ionic Systems. I was a bit sceptical beforehand as it's effectiveness, but it was absolutely superb. The paintwork looked stunning with a deep bright lustre and there was not a single water stain to be seen. I'm even looking forward to washing her again. Link to comment Share on other sites More sharing options...
apreading Posted May 1, 2005 Report Share Posted May 1, 2005 Tried it today and I have to say I am a bit dissapointed. When the car dried there were loads of streaks & water marks. Also wasnt very good at cleaning a car which was quite dirty as the spray shampoo on and sponge method just didnt seem to work as well as using a sponge soaked in soapy water which allows the debris to run away as you wash. Perhaps it would work better on a car which was cleaner to start with (I have been a bit lazy lately) but is no substitute for the normal gold class wash I do. I now need to wash the cars a second time properly - might dry using the 'aqua dry' afterwards on a couple of spots though... Link to comment Share on other sites More sharing options...
Ari Posted May 1, 2005 Report Share Posted May 1, 2005 See, I quite like washing my car properly with soapy water and a sponge, then hosing it off and chamousing it afterwards, find it quite satisfying, and very effective. Think I'll stick with my tried and tested method. Link to comment Share on other sites More sharing options...
a4tdi130 Posted May 7, 2005 Report Share Posted May 7, 2005 Used this for the first time yesterday (yep I know I know, it's taken me nearly 3 weeks to give my new car it's first wash . It's come up nicely but I have a few problems with it and probably won't use it again to wash the car, other than for the "auto-dry" part at the end which truly was superb. The guild quality is a bit rubbish. Especially the flimsy green rubber cover for where the shampoo goes which resulted in half a bottle of the stuff now sitting on my garage floor. Why not a screw cap?! Also, it seemed to leak - maybe my water pressure is too high but drops of water were constantly coming out from the bottom of the unit. Fine during normal use, but when on "auto-dry" it was a pain doing the roof because "normal water" kept dripping on the bits I had just covered in the filtered water. Also, it seemed to take twice as long to wash as you had to keep picking the unit up, applying shampoo to the car, then sponging, then swapping back etc. Much quicker to walk round with a bucket and sponge. Overall, I would give it 6/10. I will use normal shampoo and a sponge to wash the car, then the auto-dry filter at the end, but won't be using it again from start to finish. You have to really use a bucket and sponge on the wheels anyway so you can rinse the sponge properly, so defeats the object of having the flash "all in one" unit. Link to comment Share on other sites More sharing options...
CarMad Posted May 7, 2005 Report Share Posted May 7, 2005 The dripping might be from the connector going loose. Same thing happened to me... I thought whats all this water coming out of the bottom. A quick tighten of the connect on the unit and it was fine again. Just a suggestion. Link to comment Share on other sites More sharing options...
