beaker6667
golf electrics probs
3 posts in this topic
just got an m plate 16v thats been standing for over 7 mths and the eletrics are a bit screwy,the hazardss work but the indicators dont,the rear wipers not working,the washers dont work too.anyone tell the cambelt tchange times,its done 145k with svc history.needs tlc but new to VWs.???
Just had a similar problem myself.....the car ignition just clicked dementedly when i tried to start up.....pretty sure the battery is run down cos i shamefully blush.gif dont do that many miles in it, so i'd check the main battery first of all and give it a good old charge up and go from there ECLIPSe.gif
Hi & welcome
sounds like the contacts on the col stalks are coroded try contact spray & a bit of movement
volts could be low
I would change the timing belt anyway..you can't trust to luck ...
