AnArtist1 Posted April 16, 2005 Report Share Posted April 16, 2005 Whilst bombing up this little road: Little Road I have developed a knocking noise from the front left wheel area. Can't be barrings they were replaced sometime ago. I read something, somewhere round here about worn out shocks or springs or similar, the mileage is now 88k . Is a front suspension transplant required?? Link to comment Share on other sites More sharing options...
charlie61 Posted April 16, 2005 Report Share Posted April 16, 2005 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=9889&item=4542206933&rd=1 Link to comment Share on other sites More sharing options...
cruiser647 Posted April 16, 2005 Report Share Posted April 16, 2005 That looks to be more isolated than the back of beyond! Looks a great road for the Sport! Did your car go in for the Audi recall on the front suspension? Does the noise only occur when turning/going over bumps or just cruising? Link to comment Share on other sites More sharing options...
SneakyMcC Posted April 16, 2005 Report Share Posted April 16, 2005 Does it sound high or low (above the wheel). Deffo knocking and not a rattle? Link to comment Share on other sites More sharing options...
AnArtist1 Posted April 16, 2005 Author Report Share Posted April 16, 2005 The road is Honister Pass, Lake District. The Recall, if I recall, something was done suspension wise(allegedly) when I bought it. The noise occurs at low speeds over bumpy surfaces, it sounds as if its a high noise. Can't find anything loose on the left hand side of the car, the air intake (on the right) rattles a little. On full lock there is sometimes a bit of a clunk?! I can't really tell if its a rattle or a knock but it is here to stay what ever it is. Link to comment Share on other sites More sharing options...
cruiser647 Posted April 16, 2005 Report Share Posted April 16, 2005 Might be a Track Rod End? Not sure if poking it with a stick will get it to move. They take a lot of effort to move them! If it is that, should not cost much to do. Track Rod Ends are about £30 MAX and 1 hr to fit MAX at a Stealer. balancing, steering stuff and all that, need to be done after. He says hopefully!!!! Link to comment Share on other sites More sharing options...
SneakyMcC Posted April 17, 2005 Report Share Posted April 17, 2005 We had a rattle for years it turned out to be a top link in the suspension. I'l try to get you a pisture later. Was just a muted rattle that could be heard if you weren't 'Tumping' (the stereo) and could feel slight play/wobble through the s/wheel. Post track-rod, you'll need some wheel alignment. Stealers want £200+ for the full jobbie, recently a stealer said they do a part w/a. Never been told this before Try to get actual photo if you need, lemmy'know. Link to comment Share on other sites More sharing options...
AnArtist1 Posted April 17, 2005 Author Report Share Posted April 17, 2005 A Thousand thanks yous: I shall get this to the Mechanic hero wot fitted my Black Diamonds. Link to comment Share on other sites More sharing options...
SneakyMcC Posted April 17, 2005 Report Share Posted April 17, 2005 Ahh, I've been meaning to ask if it was you who recommend the BD brakes, they're bedded in now. Not stood on'em yet but feel much, much better than the OE stuff. Thanks for the tip! You need photos of the suspension parts I had changed? Link to comment Share on other sites More sharing options...
pnifa1 Posted April 18, 2005 Report Share Posted April 18, 2005 That partial wheel alignment will be a toe in check I'd bet, any good tyre place can do a 4 wheel laser alignment toe in of the front wheels for about £20 or less, if all you've done is change track rod ends, that should be fine, as castor/camber etc won't have altered. Link to comment Share on other sites More sharing options...
beavis Posted April 18, 2005 Report Share Posted April 18, 2005 I'd be interested to know what you find. I've got a similar problem on my S8, sounds like something loose on the front. Local garage said "cant find anything wrong". Its now having some work done under warranty (seal on rear of gearbox\output shaft) and i've asked them to take a look too.. Will let you know if they find anything.. Link to comment Share on other sites More sharing options...
AnArtist1 Posted April 19, 2005 Author Report Share Posted April 19, 2005 My mechanic says its probably a Ball socket thingy and the track rod end is responsible for the 'Gerbil' sound effects from the rack in the damp. He is going to have a thorough look on Thursday. gave him the diagram from Sneaky (thanks) and it all made sense. Will let you know after that. Cheers for the assistance. Link to comment Share on other sites More sharing options...
pnifa1 Posted April 19, 2005 Report Share Posted April 19, 2005 Hey guys, I've just changed all my front links and track rod ends today!! (What a complete pain in the arse that was!!) and although much better handling now, I'm still getting a clunky rattling noise on bumpy roads from the front somewhere!, so it's just occured to me that the only thing left that it could be is the suspensiuon strut top mountings, you can't tell by pushing or pulling at them as everything is so heavy and tied together that nothing shows any play when it's up on the ramp, but I bet thats the culprit, so I'll let you know when I've changed them if it cures it, so don't forget to get your mechanic to check these too!! Paul N Link to comment Share on other sites More sharing options...
SneakyMcC Posted April 19, 2005 Report Share Posted April 19, 2005 [ QUOTE ] I'm still getting a clunky rattling noise on bumpy roads from the front somewhere Paul N [/ QUOTE ] Mine was rattling and cured by the links in my picture above... Link to comment Share on other sites More sharing options...
AnArtist1 Posted April 21, 2005 Author Report Share Posted April 21, 2005 The Good news: Clonking suspension has been cured. The mechanic spent over 2hours checking everything, concluded all is well. He then noticed the Front Left Calliper was slightly loose! Just a millimetre of play was making all the noises. He stripped it down and tightened everything CURED!!! Hurrah!! He charged me £50 Hurrah!! x2 The Bad news: I can hear all the other squeaks now!! Thanks for the help chaps Link to comment Share on other sites More sharing options...
AnArtist1 Posted June 15, 2005 Author Report Share Posted June 15, 2005 Well nearly a month on the other front calliper is now loose!!!!! Link to comment Share on other sites More sharing options...
