resh28 Posted April 9, 2003 Report Share Posted April 9, 2003 found some info for symphony radio/cd type Speed-sensitive Volume Control Information The following is the procedure on how to access the Speed-sensitive auto-volume compensation display. 1. Turn off radio. 2. While pressing and holding the Preset 2 button, turn on radio. 3. The display shows how many decibels the SVC has increased the volume. This is a display-only mode. You cannot change any settings. 4. When you are done, turn off radio, then turn it back on for normal operation. Hidden Equalizer The following is the procedure on how to access and adjust the "hidden" equalizer feature in the Audi Symphony radio. Turn off radio. While pressing and holding the Preset 5 button, turn on radio. You'll see a series of 8 digits displayed. From the factory, it's set to "55555555". You will not hear any sound when running in this mode. The first four digits correspond to the four equalizer bands (low, low-mid, upper-mid, high) for the front speakers, and the last four digits are the same for the rear speakers. The level can be set from 1 (minimum) to 9 (maximum). Turn the volume control knob to increase or decrease the level for the band (which is blinking). To advance to the next band, press the P.Scan button. When you are done, turn off radio, then turn it back on to hear the results. On some versions of the Symphony, you must also cycle the ignition key to hear the results. WARNING: Use the information at your own risk. I do not provide any guarantee of its accuracy and cannot be held responsible for any damages. Link to comment Share on other sites More sharing options...
Hants_Cruiser_UK Posted April 9, 2003 Report Share Posted April 9, 2003 Sounds good - how did you find this out ? I wonder if it works for the Concert CD/Tuner in the A4 Cabriolet that I have Link to comment Share on other sites More sharing options...
resh28 Posted April 10, 2003 Author Report Share Posted April 10, 2003 check this mate http://www.ibiblio.org/tkan/audi/radios/ you might find out from there Link to comment Share on other sites More sharing options...
lhorton Posted April 28, 2003 Report Share Posted April 28, 2003 Anyone know why my Concert radio in my A3 has suddenly started to not respond with the ignition key? As in when you turn off the ignition and take the keys out, the radio stays on. You have to manually turn the radio off. This is getting very annoying!!! Link to comment Share on other sites More sharing options...
UmmS3 Posted April 29, 2003 Report Share Posted April 29, 2003 Is there a hidden EQ on the Symphony II? Power on 1-4 are there but 5 & 6 are disabled... Link to comment Share on other sites More sharing options...
UmmS3 Posted May 21, 2003 Report Share Posted May 21, 2003 Anyone? Link to comment Share on other sites More sharing options...
sms720 Posted May 23, 2003 Report Share Posted May 23, 2003 Does anyone here actually notice the SVC on their radio? - I don't think I notice anything on my Concert II. Link to comment Share on other sites More sharing options...
s4dreamer Posted May 25, 2003 Report Share Posted May 25, 2003 I haven't noticed SVC at all in my car, and I often actually end up turning the volume up when it comes on on the motorway (it's fine around town). I have Symphony BTW. Must have a play with it to see if I can get it set up properly. Link to comment Share on other sites More sharing options...
Gaunty Posted May 25, 2003 Report Share Posted May 25, 2003 I've set up the SVC, not much use though, In my car the road noise doesn't really start getting loud until over 100mph, the SVC starts compensating at around 70-80mph, this is too low, so it gets louder too low and not loud enough when you're going faster. Link to comment Share on other sites More sharing options...
sidicks Posted June 4, 2003 Report Share Posted June 4, 2003 When I tried to use the AVC it didn't seem to make any difference - I guess that expected it to come into play well before you got to 70 or 80 mph - Surely that's over the speed limit, so it's only useful when you are travelling abroad sidicks Link to comment Share on other sites More sharing options...
