a4tdi130 Posted May 8, 2005 Report Share Posted May 8, 2005 I was watching "Pimp my Ride" on MTV this morning, an episode that I had seen before (big VW van painted green with a 40" TV fitted for the surfer). Anyway - towards the end, a scene that I hadn't spotted before, they very quickly said "I'm going to use the auto-dry on it now". They drove it outside, plugged in what looked like the Flash Car Cleaner on to a hose, and sprayed it all down. So... can you buy an "auto-dry" filter that does the same function as the last part of the Flash Cleaner?? It looked much meatier and sprayed a much larger amount of water out. The Flash one works well, but the spray that comes out is a bit puny. When I used it, not only was it dripping from the connector, but the spray was really fine and because it was windy, I had to turn the car round to do the other side as the spray was blowing back off the car before it had hit the paintwork! Link to comment Share on other sites More sharing options...
a4tdi130 Posted May 8, 2005 Author Report Share Posted May 8, 2005 Ah I think it was this ... same as the flash one by the looks of it, they were probably using the "rinse mode" which is why it was kicking out lots of water. They just call it "auto-dry" but it does the same as the Flash one. Link to comment Share on other sites More sharing options...
Booster Posted May 8, 2005 Report Share Posted May 8, 2005 Russ, I had the same thought today as I was drying my car (although I don't know why I bothered as it p1ssed it down 15 minutes later ). There must be a product that is specifically designed to dry the car only. Maybe a water ioniser? I believe all the Flash unit does is ionise the water. Link to comment Share on other sites More sharing options...
a4tdi130 Posted May 8, 2005 Author Report Share Posted May 8, 2005 Yep exactly. If you could get something that just fits on the end of the hozelok adaptor and is tube shaped so it just adds a bit of extra length to the hose that would be perfect. The Flash thing just isn't for me. Link to comment Share on other sites More sharing options...
Daz Posted May 8, 2005 Report Share Posted May 8, 2005 How about this then? Linky Link to comment Share on other sites More sharing options...
Booster Posted May 8, 2005 Report Share Posted May 8, 2005 I wonder how long it would last though? £50 would be money well spent if it did 50 washes. Link to comment Share on other sites More sharing options...
a4tdi130 Posted May 8, 2005 Author Report Share Posted May 8, 2005 Looks good but I need something that sits at the end of the hose pipe that I'm using, rather than the end that connects to the tap, because it's the same outside tap that gets used for watering the garden, filling the pond, filling the paddling pool, etc etc. I don't want to be using nice ionised water for all that, and on the other hand don't want to have to be plugging that big unit in everytime I use the car. I'm looking for something small(ish) that fits on the end of the hose pipe. Basically, just the auto-dry part of the Flash cleaner, that would be about 1/3 the size if it wasn't for the handle and shampoo reservoir. Link to comment Share on other sites More sharing options...
Tomk Posted May 9, 2005 Report Share Posted May 9, 2005 i thought that when i watched that lol seemed to work well , wish my water presure was that good i just get a dribble! Link to comment Share on other sites More sharing options...
Lagoo Posted May 10, 2005 Report Share Posted May 10, 2005 [ QUOTE ] Looks good but I need something that sits at the end of the hose pipe that I'm using, rather than the end that connects to the tap, because it's the same outside tap that gets used for watering the garden, filling the pond, filling the paddling pool, etc etc. I don't want to be using nice ionised water for all that, and on the other hand don't want to have to be plugging that big unit in everytime I use the car. I'm looking for something small(ish) that fits on the end of the hose pipe. Basically, just the auto-dry part of the Flash cleaner, that would be about 1/3 the size if it wasn't for the handle and shampoo reservoir. [/ QUOTE ] Satan, been thinking the same but i was just going to buy a couple of the Hoselock connectors! When you are done cleaning the car off its a quick insertion of the new piece of pipe with the filter. at the tap end of the pipe. I haven't found anything else that would seem to work! Link to comment Share on other sites More sharing options...
a4tdi130 Posted May 10, 2005 Author Report Share Posted May 10, 2005 Yeah it does look good... but I think it's a bit over the top for my once every 3 week cleaning needs Link to comment Share on other sites More sharing options...
Sparky Posted May 13, 2005 Report Share Posted May 13, 2005 [ QUOTE ] [ QUOTE ] Looks good but I need something that sits at the end of the hose pipe that I'm using, rather than the end that connects to the tap, because it's the same outside tap that gets used for watering the garden, filling the pond, filling the paddling pool, etc etc. I don't want to be using nice ionised water for all that, and on the other hand don't want to have to be plugging that big unit in everytime I use the car. I'm looking for something small(ish) that fits on the end of the hose pipe. Basically, just the auto-dry part of the Flash cleaner, that would be about 1/3 the size if it wasn't for the handle and shampoo reservoir. [/ QUOTE ] Satan, been thinking the same but i was just going to buy a couple of the Hoselock connectors! When you are done cleaning the car off its a quick insertion of the new piece of pipe with the filter. at the tap end of the pipe. I haven't found anything else that would seem to work! [/ QUOTE ] Buy yourself the hozelock 4-way tap. Connects 4 hozelock devices and has separate taps for each. Satan? Not the Satan is it? Link to comment Share on other sites More sharing options...
cheechy Posted May 13, 2005 Report Share Posted May 13, 2005 Sparky where have you been mate? Link to comment Share on other sites More sharing options...
dannymacca Posted May 13, 2005 Report Share Posted May 13, 2005 These look like a great idea if they last a while, anyone used one to comment on how long they last? Link to comment Share on other sites More sharing options...
Sparky Posted May 13, 2005 Report Share Posted May 13, 2005 [ QUOTE ] Sparky where have you been mate? [/ QUOTE ] I feel I've missed a massive chapter Link to comment Share on other sites More sharing options...
a4tdi130 Posted May 14, 2005 Author Report Share Posted May 14, 2005 [ QUOTE ] Buy yourself the hozelock 4-way tap. Connects 4 hozelock devices and has separate taps for each. [/ QUOTE ] Haven't seen these before, sounds good, will have a hunt round. [ QUOTE ] Satan? Not the Satan is it? [/ QUOTE ] Well, not the original... Link to comment Share on other sites More sharing options...
Sparky Posted May 15, 2005 Report Share Posted May 15, 2005 Ahhh Link to comment Share on other sites More sharing options...
