Disco300 Posted May 28, 2005 Report Share Posted May 28, 2005 Hi guys, new member locked out of 2002 VW Passat Estate. Any suggestions on the easiest way to get in. Ok you can all have a laugh but the keys, together with my house keys are locked in the boot. The lid closed and locked the keys inside ... and wouldn't you know it, NO SPARE !!!!! Link to comment Share on other sites More sharing options...
a4tdi130 Posted May 28, 2005 Report Share Posted May 28, 2005 Unfortunately you're a bit buggered... if there was an easy way to get in to the car without the key, all the thieves would know about it and all the VW Passats would have been stolen! I think the AA/RAC might be able to help, but they'll probably charge. Likewise with your local VW dealer, they might be able to duplicate a key but again it'll cost £££. Usually the cheapest way to get in to a locked car is to smash one of the side windows (carefully) and then get the glass replaced, it's usually cheaper than getting somebody to open the car. Link to comment Share on other sites More sharing options...
Calm Chris Posted May 28, 2005 Report Share Posted May 28, 2005 Try the RAC / AA they will come out FOC if you have membership. Can't remember if the boot is a cable unlock from the cabin, If so they might be able to get at it. If it's c/l control, then it could be a problem. If the passat doesn't have spilt fold rear seats, breaking a window will get you in the car, but not the boot! Bum luck, hope it works out cheap. If your in a town, might there be a auto locksmith that could help? Link to comment Share on other sites More sharing options...
Calm Chris Posted May 28, 2005 Report Share Posted May 28, 2005 Oh, Its an Estate! Link to comment Share on other sites More sharing options...
felixthecat1 Posted May 28, 2005 Report Share Posted May 28, 2005 Go round to your local Council Estate and find a gang of youths. Wander over and offer them twenty quid if they can get into your car without breaking a window. I bet you'll have a few takers. Link to comment Share on other sites More sharing options...
mulkbear Posted May 28, 2005 Report Share Posted May 28, 2005 There is a few ways 1. Brick + Window = new window + Fitting = 2. remove rear no plate drill a hole 20mm in the center of boot pull metal rod up boot open = Body repair = 3. Large screw screwed in to door lock attach slide hammer remove lock = new lock + fitting = 4. Use a welding rod, slide though top door seal pull boot release boot button up (won't work it doors are double locked)= Link to comment Share on other sites More sharing options...
autolocksmith Posted May 29, 2005 Report Share Posted May 29, 2005 What part of the country are you in? I'll put you in contact with an auto locksmith who would be able to assist. Link to comment Share on other sites More sharing options...
felixthecat1 Posted May 30, 2005 Report Share Posted May 30, 2005 [ QUOTE ] What part of the country are you in? I'll put you in contact with an auto locksmith who would be able to assist. [/ QUOTE ] All respect to you mate but I hope he's in already. Link to comment Share on other sites More sharing options...
Wobby Posted May 30, 2005 Report Share Posted May 30, 2005 Tian... do you look like your picture I bet your well sexy really Yeah.... i would hope hes got in after 2 days.... Link to comment Share on other sites More sharing options...
felixthecat1 Posted May 30, 2005 Report Share Posted May 30, 2005 [ QUOTE ] Tian... do you look like your picture I bet your well sexy really Yeah.... i would hope hes got in after 2 days.... [/ QUOTE ] What am I supposed to say to that? Link to comment Share on other sites More sharing options...
Disco300 Posted May 31, 2005 Author Report Share Posted May 31, 2005 Thanks for all of your help guys ... had to call the RAC out and the nice man got me in after about 20 minutes. Grateful for all of your comments ... especially the one about council estate scallies Link to comment Share on other sites More sharing options...
Wobby Posted May 31, 2005 Report Share Posted May 31, 2005 Our Tian... he always helps Did the RAC man do much damage?? RobK Link to comment Share on other sites More sharing options...
Disco300 Posted May 31, 2005 Author Report Share Posted May 31, 2005 Yes and no ..... sorry! He didn't do any physical damage to the car but when he "hooked up" to live up the ignition he bent a pin on the connector which resulted in a engine management warning on the trip computer. A good auto electrician spotted the problem this afternoon and all is now well Don Link to comment Share on other sites More sharing options...
Wobby Posted June 1, 2005 Report Share Posted June 1, 2005 Am i daft !! I dont understand.... how did he get in? Thanks RobK Link to comment Share on other sites More sharing options...
Disco300 Posted June 1, 2005 Author Report Share Posted June 1, 2005 What he actually did was connect a power supply to the sump sensor which lived up the ignition. Once the ignition was on he chocked the drives door and used a proder to drop one of the elec windows. Hooked the keys and that was it !!!! Link to comment Share on other sites More sharing options...
Wobby Posted June 1, 2005 Report Share Posted June 1, 2005 Nice way, better than the brick answer. So no damage at all, i will remember this way. I have nearly locked my keys in the boot twice now. Thanks RobK Link to comment Share on other sites More sharing options...
JOHNBOY2711 Posted June 18, 2005 Report Share Posted June 18, 2005 Trust your in now but here's how i got in when I did the same. Remove cover from under engine, locate oil switch from underside of engine compartment, disconnect plug from oil switch, connect a 12 volt supply to red wire, this "energises" your dashboard, when this is done you can operate the electric windows (welding rod or similar). If double locked climb through window and drop rear seats (if split) Link to comment Share on other sites More sharing options...
NigelT4 Posted November 4, 2012 Report Share Posted November 4, 2012 [ QUOTE ]Tian... do you look like your picture I bet your well sexy really Yeah.... i would hope hes got in after 2 days.... [/ QUOTE ] What am I supposed to say to that? The only way i have managed to gain access to a passat estate is to remove the rear number plate & drill a 10mm hole just above & to the right of the key hole thus exsposing the link rod to the lock. using a pair of thin nosed pliers lift the rod to unlock the tailgate. would advise looking at a diagram of lock to work out where to drill. This does work! I had to resort to this when the AA couldn't get in. The AA guy very kindly let me look at his laptop showing the lock lay out, even he was impressed how quickly i got in!! Hope this helps. Link to comment Share on other sites More sharing options...
Ian_C Posted November 4, 2012 Report Share Posted November 4, 2012 Nigel, you know what, that's absolutely fucking brilliant! Now Disco 300 can go and get into the 2002 Passat that's been locked on his drive since May 2005. I don't know where he - or any of us for that matter - would be without you. Link to comment Share on other sites More sharing options...
