Mook Posted September 14, 2005 Report Share Posted September 14, 2005 It still looks like a very neat install, albeit from a distance on a photo. Do you reckon you could predrill the Cupra spoiler and screw in from underneath to get the sides of the splitter to fit more closely to the spoiler? Or are you just talking about the splitter in the middle? This was mentioned on one of the Vortex threads - have you fitted long screws through the centre "struts" in the centre splitter to make the install more secure - just thinking about the splitter flapping at 100+ mph. On the track of course... Link to comment Share on other sites More sharing options...
Dan32 Posted September 14, 2005 Author Report Share Posted September 14, 2005 Its the sides that I'm not happy with. They don't follow the contour of the spoiler so you end up with a slight gap that you don't have anywhere else. Screws may well be going in tomorrow to try and help this. It seems secure enough but you never know. Especially on the 'track' at 100+. Was trying to avoid damaging the spoiler but its possible to pop a few self tapping screws thru the undertray which is easier to hide/replace when I sell the car. Link to comment Share on other sites More sharing options...
Mook Posted September 14, 2005 Report Share Posted September 14, 2005 Excellent! Last one for you - how much did you have to trim off the "turrets" in the middle of the splitter before fitting it? Link to comment Share on other sites More sharing options...
Dan32 Posted September 14, 2005 Author Report Share Posted September 14, 2005 I took about half off. They sit behind the original spoiler so I would start trimming small amounts off until you are happy. I was lucky and got it right first attempt! Link to comment Share on other sites More sharing options...
Dan32 Posted September 14, 2005 Author Report Share Posted September 14, 2005 And to line it up so it is in the middle, there is a grill support that seems to be smack bang in the middle of the spoiler, behind the mesh, which you can use as a reference, and then measure half way between the supports on the LCR splitter and put on some paper masking tape and a pencil line. Link to comment Share on other sites More sharing options...
Mook Posted September 14, 2005 Report Share Posted September 14, 2005 Link to comment Share on other sites More sharing options...
dubzter Posted September 15, 2005 Report Share Posted September 15, 2005 I take it then it is only sandwiched between the bumper and the engine cover. It isn't physically screwed to anything. Do you think it will be secure enough? Link to comment Share on other sites More sharing options...
FiftyPence Posted September 15, 2005 Report Share Posted September 15, 2005 All as per the previously posted thread here I havent looked personally yet but if the US front bumper is anything to go by then the lip fits above this bottom black plastic bit: undo the screws to it and the lip fits between the current black plastic bit and the blue bumper: Link to comment Share on other sites More sharing options...
FiftyPence Posted September 23, 2005 Report Share Posted September 23, 2005 I went to fit mine today but unfortunately the Euro OEM engine sump guard thingy has lips on the front which have been mentioned previously. Im going to trim these off as they do nothing AFAIK then I should be able to fit the Seat lip straight on Link to comment Share on other sites More sharing options...
Dan32 Posted September 23, 2005 Author Report Share Posted September 23, 2005 No need to cut them. Its possible to slip the splitter under the trim with these underneath and then a couple of self tappers to hold the whole lot up. Link to comment Share on other sites More sharing options...
FiftyPence Posted September 24, 2005 Report Share Posted September 24, 2005 Ill have to take another butchers, thanks Dan Link to comment Share on other sites More sharing options...
Dan32 Posted September 24, 2005 Author Report Share Posted September 24, 2005 It is a bit fiddly but if you start with a self tapper at the front corner and work your way back towards the wheel arch it will bend into place a lot better. I ended up with 3 self tappers down the sides and none in the front and it seems to be fine. I was lucky enough to have unlimited use of a 'test track' the other day and it stayed on all the way to 135mph. Link to comment Share on other sites More sharing options...
dubzter Posted September 25, 2005 Report Share Posted September 25, 2005 Dan any chance you could take a photo of where you put the self tappers. Do they fit in the original mountings or have you just put them into the bumper? Link to comment Share on other sites More sharing options...
Dan32 Posted September 25, 2005 Author Report Share Posted September 25, 2005 I'll try and get the camera under there but its a bit tight! I just put some tappers in where I thought they would a: not notice and b: hold the splitter on there. I know its not the best idea, making holes in the front bumper but the chances of anyone actually seeing these tiny holes, if I ever sold it,is minimal and could easily be repaired if need be. Link to comment Share on other sites More sharing options...
