pugboy Posted November 28, 2005 Report Share Posted November 28, 2005 Hi, I have purchased a second hand VagCom cable and want to use it on a Passat. Where is the port and does anyone have any tips? I'm trying to diagnose a faulty MAF sensor. Giving it a go at 12:30 so asap please! Cheers. Link to comment Share on other sites More sharing options...
Paul Posted November 28, 2005 Report Share Posted November 28, 2005 The passats i have scanned have the port in the centre console, by the handbrake. Under the rubber mat. (Ie the place you might put pens and loose coins) my advice is DONT scan airbags unless you have read warnings on vagcom site Maf is a funny one. They can fail anywehere between partially (most common) with no error, or totally with an error. if you knew what range of peak airflow was expected over it, you could log it, but i am afraid i dont know what figure you should expect. Link to comment Share on other sites More sharing options...
pugboy Posted November 28, 2005 Author Report Share Posted November 28, 2005 Thanks. Hopefully it is in that spot on my mates 2000 model. My 2001 facelift model doesn't have that. Link to comment Share on other sites More sharing options...
Paul Posted November 28, 2005 Report Share Posted November 28, 2005 look through a few of these possible locations... http://www.ross-tech.com/vag-com/cars/dlc.html Link to comment Share on other sites More sharing options...
Wobby Posted November 28, 2005 Report Share Posted November 28, 2005 I have a 2001 facelift model and its under the ingnition barrel and to the left. Takes a bit of seeing!!! Link to comment Share on other sites More sharing options...
pugboy Posted November 28, 2005 Author Report Share Posted November 28, 2005 Well the bloody thing wouldn't fit! The cable would fit the plug, but the gap in the plastic was to small for the cable by a few mm! Will see if it fits mine. Link to comment Share on other sites More sharing options...
Paul Posted November 28, 2005 Report Share Posted November 28, 2005 From ross-tech site PAGE HERE [ QUOTE ] "Tight diagnostic sockets" Some models have very tight trim around the diagnostic sockets. The gap between the trim and the socket itself is so small it is in violation of the SAE J1962 specifications. All of our current Interfaces (shown above) fit fine in these these vehicles. Some of our older interfaces as well as many third party interfaces use OBD-II connectors that do not fit these vehicles well. US Models: 1996 Audi A4. 1996 and 1997 Audi A6 Sedan, all 1996 and newer C4/4A Chassis Audi A6 (includes 1996 and 1997 Audi A6 Sedan and 1996 - 1998 Audi A6 Avant). European Models: All B5/8D Chassis Audi A4/S4/RS4. All 1997-2001 B5/3B VW Passat (before facelift). All 1996 and newer C4/4A Chassis Audi A6/S6/RS6. Example of a car with tight trim around the diagnostic connector. This is a 1999 European model Passat. [/ QUOTE ] Link to comment Share on other sites More sharing options...
chats Posted December 8, 2005 Report Share Posted December 8, 2005 Plugged mine in yesterday for the first time, (2002 TDi 130) and half the 'panels' seem to be missing. Looking particularly for the auto-lock feature, and assumed it would be in central locking. Am I missing a trick? Plug is above the brake pedal if you've not found it yet, in the trim. Link to comment Share on other sites More sharing options...
Paul Posted December 8, 2005 Report Share Posted December 8, 2005 Ive not done autolock on any VW, but certainly on Audi, sometimes they are under different modules. http://www.ross-tech.com/vag-com/cars/passatb5.html check module 46 - Cent. Conv Link to comment Share on other sites More sharing options...
chats Posted December 9, 2005 Report Share Posted December 9, 2005 Thank you, missed that link when I downloaded the program. Will report back when I've given it a go over the weekend. Link to comment Share on other sites More sharing options...
chats Posted December 20, 2005 Report Share Posted December 20, 2005 Done, works, auto-locks at about 5mph. Link to comment Share on other sites More sharing options...
Wobby Posted December 20, 2005 Report Share Posted December 20, 2005 what year passat is this on? Link to comment Share on other sites More sharing options...
chats Posted December 23, 2005 Report Share Posted December 23, 2005 2002 Link to comment Share on other sites More sharing options...
Wobby Posted December 23, 2005 Report Share Posted December 23, 2005 I couldn't do this on my 2001 Passat, what controller did you recode and how did you do it? I followed the Audi TT coding (works on newer Passats!) but quickly came stuck as mine didn't have the module i needed to recode. I tried recoding the module that did control the central locking (forgot the number) but it stopped my doors locking and i had to revert back to the old code. Any help really appreciated Link to comment Share on other sites More sharing options...
Paul Posted December 24, 2005 Report Share Posted December 24, 2005 Wobby, have you tried the ross-tech instructions in my post above? its for 1998-2004 b5 Passats. Link to comment Share on other sites More sharing options...
Wobby Posted December 26, 2005 Report Share Posted December 26, 2005 I thought i had, i will have another go when i get chance Thanks Link to comment Share on other sites More sharing options...
chats Posted December 27, 2005 Report Share Posted December 27, 2005 Has to be an activated copy of vag-com to make the change. Then follow the instructions on Ross Tech site as above. Note where to go differs dependent upon if you have electric windows or not. I've now got a print out of the Ross Tech page with the cable to refer to. I used the 311 version download to do mine, although I can't see the difference with the later version but I'm sure there is a difference, and a search on Google. Link to comment Share on other sites More sharing options...
