Golf Immobiliser/Ignition Problems- Help Please
  • Please log in to reply
5 replies to this topic
#1 sdmcintyre
sdmcintyre
    Fiat 500
  • Members
  • PipPipPip
  • 44 posts
Posted 08 January 2006 - 02:48 PM
I have a 2001 1.8T. Recently when I unlock the door and turn the key the dash display goes blank and nothing happens(not even the starter turning over). The symptoms are similiar to having disconnecting the battery. When I open and close the door it seems to reset itself, ie the clock and trip computer. I have checked the battery connections and they look fine. This has now happened 4/5 times.
Does anyone have any ideas?
I'm thinking that maybe the battery in the key fob maybe need changing??
Any advice greatly apreciated.
Thanks
#2 hotdog
hotdog
    Panties are proof
  • Members
  • 2,597 posts
Posted 08 January 2006 - 03:04 PM
Take the cables off the battery terminals and give them a good clean. Put them back and cover them in vaseline, yes really!
If you still have problems I reckon your ignition switch is up the spout. Does the dash light up if you wiggle the key in the barrel?
All I wanted to do was stroke her hair...........
#3 sdmcintyre
sdmcintyre
    Fiat 500
  • Members
  • PipPipPip
  • 44 posts
Posted 08 January 2006 - 03:13 PM
No, as soon as I put the key in the ignition the display goes blank.
I can't force it to happen, seems very random.
I'll try cleaning the connections, cheers
#4 hotdog
hotdog
    Panties are proof
  • Members
  • 2,597 posts
Posted 08 January 2006 - 03:29 PM
Mulkbear will know more about the immobilisor side of things, but the whole dash going blank sounds like a poor connection to me.
Do any of your other electrics go off??
Im not 100% on VW security. I think if the transponder was up the spout, you would be able to turn the ignition on but the car wouldn't start?
#5 sdmcintyre
sdmcintyre
    Fiat 500
  • Members
  • PipPipPip
  • 44 posts
Posted 08 January 2006 - 04:19 PM
yeh all electrics go dead when it happens
#6 pocket
pocket
    Shank's Pony
  • Members
  • Pip
  • 1 posts
Posted 04 October 2010 - 07:38 PM
I had same problem for about 4 months on and off on 99 BORA.
Turned out to be a dying battery. Stuck a new heavy duty on and its not happened for 14 months.think it cured it.
