DERVMonkey Posted January 12, 2006 Report Share Posted January 12, 2006 I have a '96 A6 2.5tdi140 Quattro. When negotiating speed humps or bumpy roads I get a thump/knock which sounds as if it is coming from the drivers side wheel/bulkhead area. Also when travelling at anything over 20mph there is road noise from this area - more if the car is turning to the right. Someone has suggested this may be the strut top mount bush failing, if so is this a DIY job?? Do I have to remove the whole strut or can I replace it in situ?? Any replies would be appreciated. Link to comment Share on other sites More sharing options...
cruiser647 Posted January 12, 2006 Report Share Posted January 12, 2006 Sounds like it might be the strut OR just the tie-rod knuckle thingy being knackered. Not sure about replacing it in situ. If you are good at DIY, then yes, you can do it. If not, any tyre/exhaust outfit will be able to sort it. Is your TDi Quattro auto or man? I could never find an auto one - hence I bought the 2.8 (30v) Q Auto instead. Link to comment Share on other sites More sharing options...
DERVMonkey Posted January 12, 2006 Author Report Share Posted January 12, 2006 i've had both tie rod ends replaced, the garage melted one trying to adjust it after using a heat gun on it which was nice! The car's a 6 speed manual with leather and air-con, v rare in this country or so i believe - i've only ever seen one other for sale in 3 years of owning it. Link to comment Share on other sites More sharing options...
