karllap Posted February 4, 2006 Report Share Posted February 4, 2006 The engine management light was on my Golf V5 2002, the readout said Code 16516 / 02 sensor circuit B1 S1 P0134 No activity Detected The garage diagnosed from this that precat Lambda was shafted and changed it, reset the codes and everything was fine for 3 days but then it came back on with the same fault. When they reset the codes the management light went of, stayed of for a few days again then caim back with the same fault. Has anybody any idea what this could be. Also, I don't know if its relevant or not but the low screen water light is on, I've shorted the switch out and it stays on. HELP! Link to comment Share on other sites More sharing options...
Mook Posted February 4, 2006 Report Share Posted February 4, 2006 Welcome to Tyresmoke Karllap I don't have an answer for you, but one of our resident techs will be along shortly - Mulkbear or Tobes are the most likely to pipe up on this one. Link to comment Share on other sites More sharing options...
karllap Posted February 4, 2006 Author Report Share Posted February 4, 2006 Cheers mate, I've managed to sort the washer sensor problem now but I'm still stuck with management light. Link to comment Share on other sites More sharing options...
asta Posted February 5, 2006 Report Share Posted February 5, 2006 Looks like they didnt fix the source of the problem. Something must have caused the lambda sensor to fail and whatever that something is it hasn't been fixed. I'd go back to the garage. Link to comment Share on other sites More sharing options...
karllap Posted February 8, 2006 Author Report Share Posted February 8, 2006 In fairness trhe computer says that the lambda was faulty so thats why they changed it, when I take it back all they can really do is look at the diag read out which will say its the Lambda again . I've noticed that if I disconnect the battery it resets again, and again the light will stay off for a day or 2 then come back on. Has any body any idea at all what could be causing it? Thanks Link to comment Share on other sites More sharing options...
Skidmark Posted February 8, 2006 Report Share Posted February 8, 2006 Have they checked the wiring & the plug to the lamda ? You may have a broken wire and/or poor connector....water getting in or corrosion in the plug itself. cheers Link to comment Share on other sites More sharing options...
joffan Posted February 12, 2006 Report Share Posted February 12, 2006 I had this problem with my Mk5 GTI,turns out the wire connecting the Lambda was at fault. I'd ask them to have a look at that if I was you. Link to comment Share on other sites More sharing options...
