000000
Charcoal Filter
10 posts in this topic
Anyone else had trouble with that annoying ticking noise?.Seems to be coming from charcoal filter.Only trouble is its intermitent.Whats the chances of it ticking when you let techie listen to it at stealers...yes thats right zero! Does it affect the overall running of the engine at all? Or is it something you just have to live with? openfire.gif
As far as I know it doesn't affect running at all. Can't remember anyone else having one replaced.
Are you using "ripping Reg Vardy" as your dealers? I'd suprised if they even open the bonnet before not hearing any noises grin.gif
No Hotdog.Iuse Arthur Prince in Loughborough.Normally they're quite helpful(certain techies anyway),all they said was"they do tick anyway but we could fit you a new one and be no different".So i left it at that.But i was just wondering if anyone else had this issue. sportifs2.gif
Mine has a squeaking noise from under the bonnet when its hot so I guess I'll have to get the lube spray out smile.gif
Or, I might just take it to the dealers as there's a few other bits I want looked at
I've never noticed the ticking filter but I know there were noisy fuel pump issues on early cars.
Something else that ticks quite loud aswell is the fan belt tensioner,which is also located near to the charcoal filter.Even techie said it was hard to distinguish which was louder! smashfreakB.gif
Had mine replaced a few weeks ago it should tick slightly that's normal however mine was vibrating really badly sometimes. It did'nt do it when the tech had a look but they changed it no problem the new one according to the tech is slightly different in design. If it had'nt been covered by warranty it was over £120 iirc 169144-ok.gif
Glad your sorted out David.I'll have another go at stealers again about filter and tensioner.Just lately seem to to be spending every saturday morning down there.But why not while its still under warranty. SAUER0421.GIF
The ticking is completely normal Red32 - nothing to panic about. You can find out if something else is ticking by simply removing the connector from the top of the charcoal filter for a couple of minutes. Don't forget though that the injectors tick away (quietly) like crazy.
