martin9aj Posted March 13, 2006 Report Share Posted March 13, 2006 Hey Ok, so I have just discovered that I have a small oil leak coming from the rocker / cam cover gasket, not the worst place but still a leak! The problem is I have a 1997 Polo 1.4 16v AFH engine! and you cant buy a gasket seperate, meaning you have to buy the WHOLE cylinder head cover which includes the gasket...we`re talking £130 from VW! What a rip off! I only need the gasket which is probably worth £2!!! Ive tried GSF / EURO / ALLPARTS and the usual others but none can supply the rocker cover gasket alone AND it DOESNT come in with a head gasket set just to make things worse Where can i get a gasket for this??? Anyone got a new one spare??? Any ideas??? ANYONE HAD THE SAME PROBLEM??? Thanks Link to comment Share on other sites More sharing options...
daz60932 Posted March 13, 2006 Report Share Posted March 13, 2006 If your handy with tools maybe try local scrappy's/VW breakers? Link to comment Share on other sites More sharing options...
Tobes49 Posted March 13, 2006 Report Share Posted March 13, 2006 where is it leaking from? Is it by the humps for the camshaft or on a flat section? Link to comment Share on other sites More sharing options...
martin9aj Posted March 13, 2006 Author Report Share Posted March 13, 2006 I cant really tell as i havent taken cover off but it is coming from the very left hand corner as you look at it Link to comment Share on other sites More sharing options...
pingpongpo Posted March 14, 2006 Report Share Posted March 14, 2006 You could always take the old one off and use it as a template to cut a new one in some gasket material. Link to comment Share on other sites More sharing options...
SteNova Posted March 14, 2006 Report Share Posted March 14, 2006 is it rubber or cork, if it's rubber i'd be tempted to remove it wash it and refit with some sealer Link to comment Share on other sites More sharing options...
martin9aj Posted March 14, 2006 Author Report Share Posted March 14, 2006 yeah its rubber so im thinkin, clean it up then silicone sealant... any ideas which sealant? Link to comment Share on other sites More sharing options...
SteNova Posted March 15, 2006 Report Share Posted March 15, 2006 clear or black rtv, put it on do it up, then return 20 or so mins later and tighten it up after the rtv has gone off a bit Link to comment Share on other sites More sharing options...
pingpongpo Posted March 15, 2006 Report Share Posted March 15, 2006 I'd use some blue hylomar sealant rather than silicone. It's designed for gaskets and stuff although I'd double check using it with rubber although I would imagine it would be alright. Link to comment Share on other sites More sharing options...
Tobes49 Posted March 15, 2006 Report Share Posted March 15, 2006 [ QUOTE ] I'd use some blue hylomar sealant rather than silicone. It's designed for gaskets and stuff although I'd double check using it with rubber although I would imagine it would be alright. [/ QUOTE ] Hylomar is non setting and would be no good for this. Link to comment Share on other sites More sharing options...
Tobes49 Posted March 15, 2006 Report Share Posted March 15, 2006 [ QUOTE ] I cant really tell as i havent taken cover off but it is coming from the very left hand corner as you look at it [/ QUOTE ] Sounds like the humps where the camshafts are. These parts have silcone sealer in the corners from the factory. just remove the cover clean the seal and the face of the head, use a High temp silcome sealer. Put a very thin film all the way round a small blob on any corners. That should cure it. Just make sure the oil breather system is clear as this can create oil leaks if blocked. Link to comment Share on other sites More sharing options...
