trevorwoodham Posted April 8, 2006 Report Share Posted April 8, 2006 my 4.o chimaera with power steering has started to get stiff more so in the straight ahead position. have checked possible causes like knuckle joints,upright bushes, steering column and the like all of which appear ok. which suggests faulty pump or rack. power steering oil level is correct and no excessive signs of air. any suggestions please before I waste any money thankyou. Link to comment Share on other sites More sharing options...
kerbside Posted April 12, 2006 Report Share Posted April 12, 2006 I assume you have also checked for leaks? Bit of a messy one here! Get an assistant to sit in the car with the engine running and turn the steering on full lock either way. Slacken the high pressure pipe on the pump. There are 2 pipes, the high pressure one is the one that is screwed in/held on with banjo bolt (depending on year). Fluid should spray out. If it trickles you know the pump isnt pumping. If it does try the same again at the rack (best done on a ramp). On full lock you should get fluid under pressure from both steering rack pipes. If you don't you know the rack is binfood. This method is effective but messy so don't do it on a new monoblocked drive! And remember to top the fluid back up after you have slackened each pipe. Link to comment Share on other sites More sharing options...
trevorwoodham Posted April 13, 2006 Author Report Share Posted April 13, 2006 Thanks for the info, I will give it a go hopefully its going to be the pump thats faulty Link to comment Share on other sites More sharing options...
trevorwoodham Posted April 14, 2006 Author Report Share Posted April 14, 2006 pressure test done pump does seem to be producing pressure as oil came out banjo on high pressure side of pump at quite a rate. both ends of the rack did produce oil but not at the pressure I was expecting. I suppose if the rack is working though not at full capacity that was the kind of result you would get, So still inconclusive as to fault to9 some extent. I believe TVR car recondition the racks so thats probably the next step enless anyone has one for sale? Link to comment Share on other sites More sharing options...
trevorwoodham Posted April 20, 2006 Author Report Share Posted April 20, 2006 car is now perfect, nothing to do with pump or rack, having further checked uj,s on intermediate shaft having removed column found top uj totally siezed up. 50 quid for a new one though and the car is better than it has ever been. Link to comment Share on other sites More sharing options...
kerbside Posted May 21, 2006 Report Share Posted May 21, 2006 Sorry about the mess I caused! Could be TVR at the parts bin again, Vauxhall Vectras and Ford Fiestas suffer similar steering column problems. Glad its sorted! Link to comment Share on other sites More sharing options...
