skifly Posted May 30, 2006 Report Share Posted May 30, 2006 My sister just gave me a call as her car speedo is not working - aparrently it keeps jumping all over the place every so often. I suggested she check fuses but to be honest if a fuse had gone i would expect it all to be dead?? Any ideas - its a MK IV 1.4 Golf if i am correct? Really dont want to get it into the stealers as no warranty left plus she is a blonde student prime for a stealers bull Any ideas guys?? Link to comment Share on other sites More sharing options...
mb Posted May 30, 2006 Report Share Posted May 30, 2006 The fact it is twitching suggests a failing speedo cable - although I am suprised as I would expect it to be driven electrically. I would remove the clocks (only 2 screws) & see if a cable is coming up to the them to drive the speedo if so then a new cable is what you need - if it is electronic then I would suggest checking for chaffed wiring down by the gear box as that is where it will take its feed from & the fact it is twitching suggests and intermittent fault. If you do have a cable drive you will proably find you can pull the insert out and just replace the actual cable rather than the cable & sleeve. If you disconnect the wiring to the clocks make sure you don't get turn the key in the ignition or the airbag light will come on & you will need a trip to the dealer or vagcom to reset this. HTH Martin Link to comment Share on other sites More sharing options...
skifly Posted May 30, 2006 Author Report Share Posted May 30, 2006 will see what can be done then - might have to plan a trip up to leeds at the weekend...! Not sure if its something i really want to be attempting! Link to comment Share on other sites More sharing options...
skifly Posted May 30, 2006 Author Report Share Posted May 30, 2006 here is the quote from her email she just sent - might help...? [ QUOTE ] I think the car has an electrial problem with the speedo. It seems very unresponsive when im braking, and when i accelorate, it moves up, but then flicks down to 0 and generally flicks around from about 20mph below to 20mph above the approximate speed im doing. When i change gear it drops drastically, even tho my speed does not drop at all. I was doing about 20mph this morning and it said i was doing 60!!! [/ QUOTE ] Link to comment Share on other sites More sharing options...
skifly Posted June 18, 2006 Author Report Share Posted June 18, 2006 well the dealer wants £200 to put it on the computer to do a diagnostic (Mk4 golf) then plus the parts for whatever seems to be the problem. She has been drving it like it is since my first post which is obviously pretty unsafe. Any ideas what could be causing it or anyone around leeds today with VAGCOM (if it even works with it!!) Link to comment Share on other sites More sharing options...
9969 Posted June 19, 2006 Report Share Posted June 19, 2006 Have you tried dis-connecting the battery for 5 minutes ? That should re-set the system Failing that it's probably the cable Link to comment Share on other sites More sharing options...
R32North Posted June 19, 2006 Report Share Posted June 19, 2006 Have you PM'd Mulkbear, he'll know what type of system is on that car and what to do to resolve the issue ! Link to comment Share on other sites More sharing options...
skifly Posted June 19, 2006 Author Report Share Posted June 19, 2006 nope not yet... will drop him a pm in a sec... Link to comment Share on other sites More sharing options...
mulkbear Posted June 19, 2006 Report Share Posted June 19, 2006 Your have a PM skifly Link to comment Share on other sites More sharing options...
skifly Posted June 19, 2006 Author Report Share Posted June 19, 2006 cheers... Link to comment Share on other sites More sharing options...
