AUDI A4 2.5 TDI QUATTRO 1999 NON START
  • Please log in to reply
14 replies to this topic
#1 DOUGP
DOUGP
    Shank's Pony
  • Members
  • PipPip
  • 12 posts
Posted 30 May 2006 - 07:17 PM
ENGINE CUT OUT GLOW PLUG LIGHT CAME ON. NOW REFUSES TO START WILL TURN OVER BUT DOESN'T FIRE.BLEW THE ENGINE MANAGEMENT FUSE No. 34 CHANGED FUEL FILTER NO FUEL IN PIPES CHECKED IN THE FUEL TANK CLEANED IT OUT. SENT ECU AWAY TO BE CHECKED NO FAULT FOUND. TIMING BELT CHANGED 5000 MILES AGO . AFB ENGINE CODE CAR HAS COVERED 175000 MILES
/ubbthreads/images/graemlins/smashfreakB.gif
07 Golf GTI Black,18"Monzas,Leather,MFS,Cruise etc.... Love it!!!
#2 kite
kite
    Can't Type Fast Enough
  • Members
  • 2,758 posts
Posted 30 May 2006 - 07:55 PM
stop shouting.
If there's no fuel at the filter is there a pump in the tank that's not working ?
Oh welcome to TSN
/ubbthreads/images/graemlins/ECLIPSe.gif
B6 2.5 TDIQS leather/alcantara heated fronts,front and rear PDC,xenons, dipping rear view and wing mirrors, chilled glove box, cruise, interior lightpack, rear blinds,RNS-E, sunroof, storage pack, silver mirror caps,
#3 DOUGP
DOUGP
    Shank's Pony
  • Members
  • PipPip
  • 12 posts
Posted 30 May 2006 - 08:06 PM
Replaced electric pump in tank discovered later that all it does is suck fuel into the reservoir that is in the tank. The diesel pump on the engine sucks the fuel up. Before I spend a fortune on a new pump I just wondered if there could be any other areas worth pursuing
#4 kite
kite
  • Members
  • 2,758 posts
Posted 30 May 2006 - 08:08 PM
What does fuse 34 protect.
for the fuse to blow something gotta be wrong !
#5 DOUGP
DOUGP
    Shank's Pony
  • Members
  • PipPip
  • 12 posts
Posted 30 May 2006 - 08:15 PM
All it says in the handbook is engine management that is why I thought it might be the ECU. I've had it hooked up to a diagnostic machine a few codes came up, I don't have the codes at hand but it doesn't point to anything specific
#6 kite
kite
  • Members
  • 2,758 posts
Posted 30 May 2006 - 08:17 PM
Have you got fuel at the injector's ?
#7 DOUGP
DOUGP
    Shank's Pony
  • Members
  • PipPip
  • 12 posts
Posted 30 May 2006 - 08:50 PM
Hooked up a seperate tank of diesel direct to fuel filter with an electric pump. Attempt to start and bleed through the injectors one by one and diesel comes squirting out the top of the injectors when releasing the nuts. Maybe just fuel that is lying in the pump or not at the required pressure I don't really know.
#8 kite
kite
  • Members
  • 2,758 posts
Posted 31 May 2006 - 07:00 AM
Sounds like you have fuel at the cylinders,
Can't think why it won't start /ubbthreads/images/graemlins/EEK2.GIF
#9 DOUGP
DOUGP
    Shank's Pony
  • Members
  • PipPip
  • 12 posts
Posted 19 June 2006 - 09:45 PM
Just for information for anyone else having trouble with there 2.5 tdi V6 which refuses to start, the diesel injection pump was the problem with my car. Apparently a common fault once they have passed 100 000 miles, so mine did well to last 175000!! To buy a new one from audi is approx £1200 + VAT but I managed to source a low mileage secondhand one for considerably less. Reconditioned ones are also available for a good saving on new audi part. Not exactly a five minute job because the whole front of the car has to come off to gain sufficient access to remove the pump. Be prepared for a big bill unless you have a friendly mechanic who can do it on the cheap for you !
#10 bradw
bradw
    Ford Ka
  • Members
  • 62 posts
Posted 10 September 2006 - 01:51 PM
yikes.
I pray to god that isnt what is wrong with my car..
/ubbthreads/images/graemlins/frown.gif
It is possible for the pump to fail whilst driving?
B5 2000 A4 Avant 2.5 TDI Quattro, Auto Triptronic
#11 Atomic
Atomic
    Audi S3
  • Members
  • 1,482 posts
Posted 10 September 2006 - 02:48 PM
yikes.
Of course it's possible.
#12 bradw
bradw
    Ford Ka
  • Members
  • 62 posts
Posted 10 September 2006 - 02:58 PM
and the effects whilst driving would be what?
#13 cruiser647
cruiser647
    BBC Correspondant
  • Members
  • 30,914 posts
Posted 13 September 2006 - 10:43 AM
Engine stops. Car might roll to a stop somewhere. Hope you have good control over it and in a good enough position to control it!
There is no real substitute for more cylinders!
#14 bradw
bradw
    Ford Ka
  • Members
  • 62 posts
Posted 13 September 2006 - 08:15 PM
in that case; thats exactly what occured to me @ 60mph!!
my p/steering went, and I luckily managed to muscle it into a layby 100 yards or so ahead of me when the engine died.
Expensive business these Audi's /ubbthreads/images/graemlins/wink.gif
#15 sjf1978
sjf1978
    Shank's Pony
  • Members
  • Pip
  • 1 posts
Posted 07 August 2010 - 05:47 PM
I had this pump problem and cost me 1200 quid! ouch... on my A4 rag top sline 2.5 tdi but few months later I'm now getting some strange rattling noise that seems to follow a sequence... I took it my local garage but they seem to think its a valve problem and needs the front taking off again! Car still drives but I've stopped driving it in fear it makes things worse.. they said to get a 2nd opinion from Audi as not confident its that... I know this is a long shot but anybody hazard a guess! I thought it was a belt type problem.... cheers
