lazydragon Posted June 3, 2006 Report Share Posted June 3, 2006 Hi all. I picked up my GTi earlier this week and enjoyed it a lot. Still trying to run in the engine. Please help me with out here: Q1. The ‘menu’ button on the steering wheel does not seem to activate. I tried in at ignition. Also tried: after engine has started, and holding the button for a few seconds. Nothing? Is it a fault or just not available to Australian GTis? Q2. The passenger doors cannot be opened from the outside. Is this programmed in the menu? I have tried the unlock remote control (pressing twice / holding), but the car will only unlock the driver side door Thank you Link to comment Share on other sites More sharing options...
nhs Posted June 3, 2006 Report Share Posted June 3, 2006 Some more information is needed to answer your question, as different options apply to different set ups. This is because some you can change yourself and some have to be changed at the dealers. Do you have "Highline" display? do you have the multifunction steering wheel? do you have cruise control? do you mean the steering wheel or the stalk regarding menu? The door locking/unlocking thing is probably how the car is set up, need to press twice for about 0.5 secs each time to get all doors to unlock with the remote, otherwise will open drivers only (on the set up that it sounds like you've got set up) Does the passenger door unlock with the "unlock" button on the inside drivers door? If not then your door may have a fault and need the dealers help Link to comment Share on other sites More sharing options...
lazydragon Posted June 3, 2006 Author Report Share Posted June 3, 2006 The display shows temp, travel info, petrol usage, etc Yes, multifunction steering wheel Yes, cruise control I was refering to the menu button on steering wheel (above the OK), not the stalk Yes, the passenger door unlock with the unlock button. But I will try the remote again tomorrow. Thanks :-) Link to comment Share on other sites More sharing options...
nhs Posted June 3, 2006 Report Share Posted June 3, 2006 At stationary, shut doors and put on seatbelt. You should then be able to set up discetionary functions on the highline using the "menu" toggle When the vehicle is moving >5mph, then this setup menu should be inaccessible, but you can toggle through the rest of the menus. Use the "OK" to toggle from 1 to 2. Link to comment Share on other sites More sharing options...
petsy Posted June 3, 2006 Report Share Posted June 3, 2006 is there a comprehensive guide somewhere on what each option actually does? Link to comment Share on other sites More sharing options...
toti Posted June 4, 2006 Report Share Posted June 4, 2006 Have you got Sat Nav Lazydragon? If you do you've got Highline, if not you've got Midline. Link to comment Share on other sites More sharing options...
lazydragon Posted June 4, 2006 Author Report Share Posted June 4, 2006 No SatNav. So I assume the Menu button won't work if you've a Midline display then? Oh well, thank you for the feedback Link to comment Share on other sites More sharing options...
canberragti Posted June 4, 2006 Report Share Posted June 4, 2006 Just got my new GTi and I'm having the same problem as lazydragon. That it, the Menu button doesn't work. Does anyone know if the dealer can change some options for me? I want to disable the coming/leaving home (headlights left on for 30sec)and auto-door locking features.. Link to comment Share on other sites More sharing options...
nhs Posted June 4, 2006 Report Share Posted June 4, 2006 These can be changed by the dealer, or by anyone else that has VAG COM - the software on a laptop plus the appropriate connector for the GTI (found just under the bonnet pull up above the accelerator pedal) Link to comment Share on other sites More sharing options...
