jamiek
1999 110 tdi
7 posts in this topic
Anybody had any ecu problems with there 110 tdi from 1999 the one with the airbox on the right.Or is it a rumour??? confused.gif
I've not heard anything of that. What rumour have you heard?
HEARD THAT THE ECU WOULD SOON F**K UP AND NEED AN UPGRADE LOOK AT HONEST JOHNS SITE...
Do us a favour. Honest Johns is a big place to start hunting. Point it out to us without shouting. 169144-ok.gif
Ok go onto honest johns site in the search box type ..toledo ecu.. and go to the forth result and read on the reason i brought this up is because i believe they use the same ecu and engine as the golf....hope this helps.
Ok then, I'll do it for you.....
Link.
Snipped the relevant bit.
Some TD 110s had a problem of stalling while coasting to a standstill from about 15 mph in neutral. The cure was to replace the ECU, but if the car was a personal import out of its 12-month pan-Euro warranty, the owner had to pay. This problem now seems to be coming back on high mileage TDI 110s. VAG acknowledges a fault with the ECU (038 906 018 BM) and specifies an upgraded unit (038 906 018 GQ) at £695.00 + VAT. According to VAG technical, this problem will eventually occur with all ECUs of this part number, so a second hand part may only be only a short term cure.
Must be true then, as I've never heard of Honest John getting anything wrong. I take it this concerns you somewhat? In which case I'd expect to be buying an ECU sooner or later, but personally, I'd wait for the problem to occur. VW never ever get things wrong either. grin.gif
Sorry rusty nuts not got hang of saving links yet but im trying..how do you do that????
