skippy1980
* CHECK BREAK PADS *
5 posts in this topic
Hi,
Have a 1999 Bora V5, at the weekend was driving about and we had a real bad storm and the roads really wet. Hit a big puddle and now have a warning that says, CHECK BREAK PADS!
This comes on and beeps every time ignition turned on.
How do i clear this?
Thanks
you need to plug in a the software...VAGCOM which will allow you to see the fault codes and then you will be able to clear the fault codes.
Okay, so you think I just need to get code cleared?
you don't think that it could have dislodged some kind of sensor?
It could be a couple of things, and dislodging the wire is one of them, so check all the connections. The sensor wires are physically connected to the pad and then up to a plug which is attached to the suspension strut.
When your pads get low, the wires touch the disk, causing them to earth, hence kicking on the light.
thanks for the reply, I will have look tonight and see what the prob might be!
cheers
