jamesXXX Posted August 15, 2006 Report Share Posted August 15, 2006 i have recently bought a 2000 gti turbo, which is standard, apart from a dump valve, and exhaust. it runs fine most of the time, but cuts out now and then. can anyone recommend the best dump valve to fit to eliminate this please? cheers Link to comment Share on other sites More sharing options...
Mollox Posted August 15, 2006 Report Share Posted August 15, 2006 The standard (diverter, not dump) valve Link to comment Share on other sites More sharing options...
jamesXXX Posted August 15, 2006 Author Report Share Posted August 15, 2006 [ QUOTE ] The standard (diverter, not dump) valve [/ QUOTE ] even if it has had a remap? Link to comment Share on other sites More sharing options...
RedRobin Posted August 15, 2006 Report Share Posted August 15, 2006 But your first post says "which is standard" Link to comment Share on other sites More sharing options...
jamesXXX Posted August 15, 2006 Author Report Share Posted August 15, 2006 [ QUOTE ] But your first post says "which is standard" [/ QUOTE ] figure of speech mate Link to comment Share on other sites More sharing options...
RedRobin Posted August 15, 2006 Report Share Posted August 15, 2006 Unfortunately such "figures of speech" make it trickier to help you. Link to comment Share on other sites More sharing options...
Mollox Posted August 15, 2006 Report Share Posted August 15, 2006 My remapped S3 runs fine on the Bosch OEM unit. As I understand it, the 1.8T is designed to run with a recirculating (diverter) valve and not an atmospheric dump valve which can lead to problems. Its a resillient unit these days. How can you be sure your issues relate to your dump valve though? Link to comment Share on other sites More sharing options...
jamesXXX Posted August 15, 2006 Author Report Share Posted August 15, 2006 very similar characteristics to a series rs turbo i had years ago mollox, which was sorted with a twin piston dump valve. can a standard one cope with the extra boost ok? Link to comment Share on other sites More sharing options...
Mollox Posted August 15, 2006 Report Share Posted August 15, 2006 Yes indeed. In all honesty, its the ancilliary hoses that are far more likely to suffer high boost-related problems. I imagine I'm running more boost than you (1.5bar) and I have no cause for concern with my diverter valve. With the OEM diaphragm diverter valves failures generate a distinctive "honking" sound in most cases. With a dump valve I'm not so sure. As I understand it, certain modifications are required to the boost circuit to accomodate a dump valve - its possible that these have not been done correctly - if you're positive that the valve is to blame...? Link to comment Share on other sites More sharing options...
