geemanr32
RCD 500 Help
5 posts in this topic
I have been trying to get hold of a wiring diagram for the RCD 500 because I want to add a mp3 3.5mm jack and a phone but need some more information to give to the fitters. I have tried VW but they have proved useless I have also called Blaupunkt and they said try VW confused.gif
Any suggestions or help appreciated
Thanks
do a search of the gti forum as I seem to recall Snoopy posting the diagram a while back.
They are usually all pinned out when you take them out - I would remove the stereo, sure you will find Tel +/- mute etc. all labelled up for you, here is a picture of the RCD300 that may help.
I can confirm that the RCD500 pinouts are identical to the RCD300
