Bison1379134007
TVR T350c Tyre Pressures (Track and road)
5 posts in this topic
Hi,
Was having a hard time getting a straight answer on this one so i thought i'd stick it up here.
On a T350c with the 18" wheels tyre pressure recommendations are:
24psi all round for normal road use
26psi all round for track use
N
well my guess would be that you whant the full contact pathc on the road. So what i usually do is take some chalk and draw a line acrost the tires. Drive around the block a few times (and resist the urg to spin em as this will void the results) and then look mat the chalk line. If it is more worn off in the center, preasure is too high. If it is more worn on the sides then presure is too low. I dont know if it will work as well for street tires but it works vary well on big mud tires.
I like it.. in fact i love it.. keep all your techincal messuring sh*t and take a lesson from the truck racing hillbilly...
Very resourcful these fellars you know!!!
When I first got the Charger, it came from Alabama kind of are where the redneck that had it before me, made an Airfilter Gasket out of a clutch plate off a Triumph motorcycle.. twas a spectacular bit of simple engineering that worked...
I've never herd of the Chalk measure.. try it Bison Lad and let me know what you find..
PS - You do know where to buy chalk right?
